Need Prop for OS 35 AX and Pipe
Reply
Old 10-31-2013, 08:29 AM
mustangman177
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Need Prop for OS 35 AX and Pipe
Hi All !!!
New to the Extreme Speed forum here. Need help with a question.
I have a OS 35 AX with Mousse can muffler on a SPAD Sickle. Currently using a MAS 10 X 6. Speed is awesome, but was told I could get more with a different prop and higher pitch ? What would you use on this set up ?
Thanks in advance
Cary
mustangman177 is offline
Old 10-31-2013, 11:20 AM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
9 x 7 is the next guess
If the plane is small and light enough with good aerodynamic qualities then a 8 x 8 prop.
combatpigg is offline
Old 10-31-2013, 12:48 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's a picture of one:
http://www.rcuniverse.com/forum/atta...8&d=1375344784
MJD is offline
Old 10-31-2013, 03:05 PM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pretty cool..!
I have a flying wing about this size on YouTube that is powered with a Fox .36 with open exhaust and a 8x6 prop. The wing is solid foam, it's thicker than this SPAD's and it's got a blunt leading edge [for good maneuvering].
110 MPH on a pair of 60 foot long .018" cables was really honkin'..somewheres around 2 seconds per lap. Each lap was about 380 feet.
This SPAD looks like it would be a lot faster, so the 9x7 and 8x8 might do pretty good.
Old 10-31-2013, 05:55 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'd lean towards the 9x7 prop for the disc area. The OP already thinks a 10-6 on that engine is fast so I guess it might be good compromise of pull and airspeed. Peak hp appears to be at 16k from what I could find in a quick search, so those prop sizes seem about right.
MJD is offline
Old 10-31-2013, 07:14 PM
HighPlains
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
9-6 or 8-7 might work better.
HighPlains is offline
Old 10-31-2013, 07:34 PM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What size engine does that look like to you in that photo..?
It looks like a .15 to me....[?]
If so, then a .35 would seem pretty fast for sure.
Even though flying wings are limited in what they'll do they are still a lot of fun to horse around with.
Scale this idea down for that Profi .049, do whatever you can to keep the weight down, do you
r absolute best to keep weight off of it, but use generous wing area, a fast airfoil and use a 5x3 prop on it when you just want to get squirrely, or a 4x4 when you want to shift into high gear a little bit.
I've wanted to build something similar with one of my .32-.36 engines..keep it as light as a feather but go with 500 sq inches or more and just be as militant about weight control as possible. I came close to accomplishing something like this idea a few years ago and it was looking really good for about 20 seconds on the maiden before the wing exploded. It was a recycled combat plane, so no tears were shed.
About 25 years ago I tried this same idea with a Fox .36 Combat Special on a converted CL Combat wing but didn't know that the HS-81 servos I selected would only last about 5 minutes in such an application trying to control a 48 sq inch elevon flap at 110 mph. IIRC the plane crashed into a massive and fresh cow paddy to make a fitting end to my RC activities that day
Old 11-01-2013, 05:00 AM
mustangman177
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, plane is definitely small and light. Is a flying wing with elevons. Will try 9 X 7 or 8 X 8. Stick with MAS ? What other brands of props do the Speed guys use ?
Old 11-01-2013, 05:03 AM
mustangman177
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.rcuniverse.com/gallery/galleryItem.cfm?itemID=233020&dummy=9835.00982629408&opener=/community/profile.cfm%3Fsection%3Dgallery%26memid%3D1690
Old 11-01-2013, 05:59 AM
aspeed
aspeed's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
APC has a 7-9" 8-8, 8-9. and a few more. The real high pitch ones will probably need someone else to launch for you with a pretty good shove for the first couple tries.
aspeed is offline
Old 11-01-2013, 09:06 AM
mustangman177
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Will give those a try. Thanks !!!
Cary
Old 11-01-2013, 07:53 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's not the cleanest airframe in the world. I have a strong feeling you will find out that 9" diameter works best. 9-6 as HP suggested is another I thought about, but the specs for the .35AX mention it being set up for peak power at lower rpm so figured that the 9-7 was a better candidate. Try them both! I am not convinced you will prefer the performance on 8" props. If this was a higher timed .35 a 9-6 would be my first guess. It might turn out well, but I imagine the engine will be over it's horsepower peak. Which somewhat defeats the purpose. It will be interesting to find out.
MJD is offline
Old 11-01-2013, 08:05 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.spadtothebone.net/freeplans.htm
40", 400 sq in.
Looks fun!
MJD is offline
Old 11-02-2013, 04:44 AM
mustangman177
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by MJD View Post
Good Cheap fun !!!!!
Easy to make-Addictive !!!
Old 11-02-2013, 11:54 AM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm assuming you will get this plane moving in the 120-130 mph range, so get some clockings........ then I would take clear packing tape and seal off all open cavities, like the wing tips to see how much difference that makes at this fairly high speed you will be flying at.. A simple "Coke bottle" plastic cowl can be made with a heat gun and even if it isn't museum quality give that a try and get some clockings with these aerodynamic improvements. It will show you first hand what is worth doing and what isn't in this speed / power range you are working with.
Old 11-02-2013, 04:49 PM
mustangman177
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks !!!
