Pusher Plane Prop
Reply
Old 05-13-2014, 03:39 AM
rcdavefly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Pusher Plane Prop
Good Morning ,
I have a pusher plane and have a APC 6x4 prop on it at this time , and would like to speed the plane up a little . I was thinking of replacing this prop with a APC 5x3 to speed up the plane but am not sure about this . Any advice would be appreciated , Thank You
David
rcdavefly is offline
Old 05-13-2014, 06:55 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Without knowing what powers the airplane, it is impossible to know what effect the prop change will have. What is the engine?
If you are talking .049/.051 power, then there is about a 9.5/10 chance changing to the 5-3 will speed things up. 6-4 is a very high shaft load for nearly all .049's and clamps down the rpm and power.
MJD is offline
Old 05-13-2014, 10:43 AM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Grish company sold a yellow nylon pusher prop of around 5 x 4 size. They are a swap meet or ebay item now. I've cut this one down to about 4.25" for a .049 powered pusher speed plane project. A decent TD should tach about 22-23,000 rpm.
You can also take your 6 x 4 APC and chop it down to experiment a little bit, but APC props work best if you can find the correct size to begin with.
combatpigg is offline
Old 05-13-2014, 10:47 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It would be good to know what the engine is. With luck it's a reedie and he has a whole catalog of props available.
MJD is offline
Old 05-14-2014, 07:33 AM
rcdavefly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Everyone
Old 05-14-2014, 07:48 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Don't forget 2 strokes will run hot with excessive shaft load, so when you then put that in a pusher setup you have potential for a temperamental arrangement. So if this is a Cox .049, I'm not a fan of that 6-4 (even in a tractor setup. Let 'em spin, keep 'em cool and happy - 5-3 good prop. I'm not saying it is a disaster waiting to happen, just not a direction I would be comfortable with.
If it is something else.. then what is it rcdf?
MJD is offline
