Profi .15 - F5D lekkie conversion
Reply
Old 07-04-2014, 07:44 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Profi .15 - F5D lekkie conversion
The Profi .049 Boomerang is sitting on the bench waiting for the fuel system and fuel cutoff mechanism.. got that figgered out, easy. I drilled a hole down vertically into the rear edge of the motor mount plate up close to the firewall. Into that is glued a small pin hinge, hinging fore and aft, with a piece of silicone tubing over the swinging end of the pin. The fuel line will exit the firewall to one side, run laterally through two eyes that center the tubing between the pin hinge and the firewall, then around to the NV. The pin hinge will have a pull wire extending out the exhaust outlet of the cowl. Pulling on this will cutoff fuel flow. I'll put a check valve on the other end of the bladder and fill from the same spot.
200 or a smoking crater?
So the next lekkie pylon conversion speed project is taking shape. The engine package is now complete with the box of goodies I got from Bill Hughes today.. including the Profi .15 pipe and pan, and bench prop. I've had the engine a couple of months but no pipes, now a nice shiny pipe to play with. Tiny stinger outlet ID, about .180" IIRC. The prop in the pic is a 3x6 flight prop. Time to make some noise on the test stand, I can't imagine how small I'll have to cut the bench prop. I will video!
The airframe choice is made, Avionik D06:
Perfect size, slick as snot on a doorknob, and it will be significantly lighter than tabled below with the IC package, so the wing loading will be stupid light. These things go like a bullet on 1kw and are stiff as a plank. If you do the arithmetic the average wing chord is about 4.2". This ought to be insane. Will of course take a while to do the morphing work and cowl, but I tried a few things on the Boomerang plug that worked okay but slowed me down from my already lethargic pace. So maybe this work will go more quickly.
[TABLE="width: 296"]
[TR]
[TD="width: 104, bgcolor: #6491f1"]Wing Span:[/TD]
[TD="width: 188, bgcolor: #243e75"]1.315 m (51.8")[/TD]
[/TR]
[TR]
[TD="width: 104, bgcolor: #6491f1"]Wing Area:[/TD]
[TD="width: 188, bgcolor: #243e75"]14 dm2 (217 sq. in.)[/TD]
[/TR]
[TR]
[TD="width: 104, bgcolor: #6491f1"]Stab. Area:[/TD]
[TD="width: 188, bgcolor: #243e75"]1.5 dm2 (23.2 sq. in.)[/TD]
[/TR]
[TR]
[TD="width: 104, bgcolor: #6491f1"]Total Area:[/TD]
[TD="width: 188, bgcolor: #243e75"]15.5 dm2 (240.3 sq. in.)[/TD]
[/TR]
[TR]
[TD="width: 104, bgcolor: #6491f1"]Wing Airfoil:[/TD]
[TD="width: 188, bgcolor: #243e75"]RL1PYmod (7.4 %)[/TD]
[/TR]
[TR]
[TD="width: 104, bgcolor: #6491f1"]Wing Loading:[/TD]
[TD="width: 188, bgcolor: #243e75"] 65 g/dm2 (20.5 oz/sq. ft.)[/TD]
[/TR]
[TR]
[TD="width: 104, bgcolor: #6491f1"]Flying Weight:[/TD]
[TD="width: 188, bgcolor: #243e75"] 1007 g (35.5 oz)[/TD]
[/TR]
[TR]
[TD="width: 104, bgcolor: #6491f1"]Radio:[/TD]
[TD="width: 188, bgcolor: #243e75"]Sub-micro servos and micro receiver[/TD]
[/TR]
[TR]
[TD="width: 104, bgcolor: #6491f1"]Motor[/TD]
[TD="width: 188, bgcolor: #243e75"] Lehner / HP220 / Mega F5D[/TD]
[/TR]
[/TABLE]
ID:	2011718   Click image for larger version
ID:	2011719   Click image for larger version
ID:	2011720   Click image for larger version
ID:	2011721   Click image for larger version
ID:	2011722   Click image for larger version
MJD is offline
Old 07-04-2014, 07:49 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The CNC pan is about as form fitting as you can get. In fact the read OD is so small I will have to be pretty creative to blend it into the nose.
MJD is offline
Old 07-05-2014, 05:53 AM
aspeed
aspeed's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You're impressing the heck out of me. Smoking hole? When flying the first time, maybe go without the pipe to get used to it, and save a bent pipe maybe. Ask me how I know about this.
aspeed is offline
Old 07-05-2014, 08:29 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got two pipes, one used and one new, the new pipe is spun from bar stock all shiny and is just gorgeous.
Could run an F2D combat prop for test flights to slow it down, trimmed so it will stage properly. Since I will have IMC I can keep it off resonance while I trim it out, I hope. With the light wing loading the aircraft will fly fine on a fraction of the engine output so that doesn't worry me.
MJD is offline
Old 07-05-2014, 08:54 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Had a nice chat with Bill Hughes today on the care and feeding of the engine, learned a lot. And I am not as worried about handling it now. I have a bench prop that will apparently pop up on the pipe easily on the bench, and he said "you will be surprised". I hope so! It's no easy feat to mount it, but I'll come up with something.
MJD is offline
