Do you want some steroids on your .40 plane ?
For sale IR40 FIRE (Ravil Ibragimov) Engine
Good condition
Spins 7,5x7,5 prop 30.000rpm
175€ + shipping
Check the engine on action:
https://www.youtube.com/watch?v=ZVs4NEtYnM4
samuel.riippa (at) gmail.com
Good condition
175€ + shipping
Spinner is 38mm, I got pipe to go whit it also. I use full carbon props. You canot use APC they won't last on 30.000rpm. Compare to New MB or DKT this IR is a lot easier to use and setup, but -2000RPM slower. We call this IR engines to "no trouble".
I think a Tru Turn will probably handle 30K just fine. If you look at the Jett or Nelson Q40 spinners: they are basically the same construction (the parts that matter anyway) ...at they're not that far from 30K when the plane's at speed. Jett has a 2" counterbalanced spinner for use on these engines (I don't know if it's on his website, but I know he makes them since I have one), and Tru Turn is a precision high quality product also.
Perhaps all you need is a custom cone and mounting nut to mate a Jett spinner to the IR engine, if you are hesitant about the Tru Turn. These things are not very hard to make with a lathe. A shop with some CNC equipment could whip those parts out for you in minutes.
A suitable engine mount will probably give you more grief. Most F3D engines are bolted to an aluminium engine pan that is glued into the front of the plane. They don't use a "firewall" like we know it.
My Feedback: (22)
I'm nervous about it, I've had 2 Dave Brown aluminum spinners and the aluminum spinner that came with the weston magnum come apart on me on engines that were barely pushing 20,000rpm. I know tru turns are about the best ones out there typically, but it still makes me nervous.
I'm ordering a JETT FAI practice motor right now, but if I can scrape a little more $$$ together I think I might have to take one of these crazy ass things.....
The Dave Brown spinners are spun aluminium sheet metal ...not even close to being in the same league as a spinner machined from solid barstock.
I don't know how the Weston spinners are made, but at that price there's a 99.5% chance it's cheap stuff from the far east. Again, not in the same league.
Those DB spinners sound like they should not be used on reciprocating engines whatsoever if the safety limit is that low.The rotational forces on the spinner are not insignificant, but they are not that scary. Esp in 2" and smaller. I'm sure none have flown apart on a TT .40 / 11-6, but 20k is not uncommon. They should have a safety limit noted somewhere.
"Vortech spinners are spun from Aluminum sheet - not molded/cast from brittle material, or machined out of expensive bar stock!"
