BEST DELTA EVER! Post your deltas
GA
This is the best delta I have ever flown, Its a Laser Arrow by Laser Models.
Engine: YS 45
Prop: APC 9x9
Pipe: MACS 1250
Fuel: Omega 10%
Servos: Hitec 645MG
Covered in StitsPolyfiber PolyTone paints
I have flown the DD, Holy Smoke, and Screemin Demon all of which fly great. But the laser arrown flies the best maybe not the fastest I would say 110-120. But my god it just so smooth tracks like a hardcore pattern ship. More vertical then I know to do with, flies inverted hands off, and rolls over faster than a politican Thats just my .02's
POST YOUR Delta Pics and why you love em
Engine: YS 45
Prop: APC 9x9
Pipe: MACS 1250
Fuel: Omega 10%
Servos: Hitec 645MG
RE: BEST DELTA EVER! Post your deltas
ORIGINAL: iflyg450
Of course I vote for the Screamin' Demon - I expect a high speed ride and a rush of adrenaline and get it every time. The tracking, smoothness, high/low speed ratio are all exemplary, and flies real nice A/E aerobatics when not rushing around at top speed, although it can do them at top speed too if the pilot is up to it. Dunno how the roll rate compares, the best I've managed is about 12 a second while climbing vertically, but I could dial in some more throw if it needs it.
MJD
ON, CANADA
ORIGINAL: MJD
Now there's some color contrast! Definitely not the fastest delta, quite possibly the slowest. Definitely a great flier.
MJD
MJD
Rob, you know how estimating speed on these little high pitched planes goes.. it sounds like it's doing 200. All I can guess is maybe 120. I've had my wife out twice trying to film it so I can at least get it dopplered, but no luck yet.
What's the story behind those 2 photos you show here? I wouldn't call you a wimp if you needed help launching the big one, I'd let that slide.
GA
ORIGINAL: combatpigg
That looks pretty evil, Fly450!
This is my favorite. It's got a .061 Cyclon, 32,000 with a 4.2x4 prop....unloads to what sounds like 36,000 or more.
15% nitro fed with a latex bladder.
The plane weighs 11-12 ozs
GA
ORIGINAL: smoknrv4
I'm with MJD on this one, If I may, the SD is so smooth, does what you want it too, and fast, with no bad tendencies! Love it!
ORIGINAL: MJD
MJD
MJD
ORIGINAL: iflyg450
The SD is a nice one I HAD one about a year ago. I was amazed at how fast it was with just a TT 46. The Laser Arrow is not fast I know but I still love it, also its no longer made. I might build another. Will need a anothet engine. the YS is a bit heavy, but that case pressure fuel system works like a champ never sags or goes lean pulling out of a dive. Plus the rear pipe make a great handle when I launch it I just grab it with a dish towel. Love the pics everyone has posted!
MJD
ORIGINAL: iflyg450
Do you have plans for that one????
The jet-thing is a delta technically? Same deal, Cyclon .061, micro radio gear, solid balsa sheet wing.
how about the vulcan delta.
[youtube]http://www.youtube.com/watch?v=AwTDAAj087I&feature=PlayList&p=B523356A9573C4C1&playnext=1&playnext_from=PL&index=39[/youtube]
Yessir! I thought of the Vulcan when thread was posted too. What a sight that was when we got to see it fly around here, forget the last time but maybe in the '70's. Noise abatement was not a concern at the time it was built, methinks..
MJD
MJD
GA
Right now I am turning 16.5K with a 9x9. The engine is runing nice and cool. So why beat it up??? Also without knowing what pipe I am using how can you tell me what header lenght I should have? Also Cutting the header down which prop should I run? Also what airframe were you runing your YS. Not being smart ***** but I am always intrested in how people tune pipes.
APC 9X9 @ 16300 is a " benchmark" number that I use for the YS 45 and I've never done it with a header that LOOKS as long as the one in that picture.
Your using a 1250 pipe which should work fine, I normally use the 1240. With the extra volume you have, I would have thought you would have had to really choke up on the header.
If your set up works.... cool, it just leaves me confused.[sm=50_50.gif]
My Feedback: (44)
ID
my advice is based on prior ownership of 45 and 60 sized YS engines along with a few years of experience as mac's product employee, your length as it is in pictures may turn the 16k plus rpm no doubt, but hows your mileage........and how does it transition back to lower throttle settings etc, we had people complain of losing plugs etc etc
GA
Thoes are good points, It does become sluggish comming out of a low speed setting to high. Should I be using a different prop? I'll cut the header down 3.5 tonight
CA
ORIGINAL: lfinney
lfinney, I have been watching your spike in posts lately and what I would like to know is very simple. WHO ARE YOU ??? If you don't tell me I will just have to bother Wally McCallister himself, Not his brother Dave although I can certainly do that too.
(P.M. me)
Sincerely, Chuck Roundy, Mather Modeler since 1997, A.M.A. 621679
My Feedback: (44)
ID
hi
my name is Lorin Finney, i was amather club member in the 92-90, period, as well as a sam' site member, but my fav place was merwin ranch for crazy stuff, i was at the time the only civilian member of the mather club, cost me alot of rounds at the non com club[8D] back when we had the nuke dump to the left of the runway[:-], now i fly here at the boise site, in taterville, do you remember when wildcountry r/c was on power inn road?[8D]
ORIGINAL: RocketRob
You bunch of sissys!
Combat anyone?
psst, hey buddy, can you gimme a hand launching this thing?
Combat anyone?
ORIGINAL: RocketRob
Combat anyone?
Combat anyone?
MJD
