patriot talk
patriot talk
post anyting patriot related.
ill start with the set up i hope to use on my future patriot.
plan on doing a set up with fouler flaps door covers, the works planes gonna be a brick but it will be a cool brick
anyway, that jett 76 could muscle it into the air with no wings so i figure im safe lol (note that im not brave enough to mount the .90 up there...)
if anyone sees any problems with my set up or has any questions, feel free and please do bring them to my attention. this is the first time ive made any serious mods to a plane (aside from minor structural additions on a couple) theres some kits out there that seriously underestemate the value of the triangle...
i restarted this since my first attempt was some waht a flop (ok it was a big flop) ill keep this one on topic and not limit it to only pics. anyont who wants to talk patriot pipe up...
My Feedback: (50)
RE: patriot talk
I'm down...
The mechanicals would probably be okay on good landings... I would choose Air if it were up to me- Spring Air actually...with the heavier set-up your shootin' for- should still be a missile...
The Jett-76 is a rear-exhaust which would need serious mods because of the firewall (Or are you gonna get the side exh. and the pic just happens to be a FIRE?) Be mindful of the prop. clearance if you end up swinging big-wood
I use Robart Scale-Wheels they are only about $10- and they look MUCH better than those others...They are harder rubber, have treads, and 2 diff. rim types- One guy on here used BVM Wheels (Alum.) and it looked awesome but $$
Servos seem fine- remember you can get similar servos for cheaper, they are called Hitec
Lastly the Hitec Eclipse is a great radio that will serve your needs for years- I use a 9C however [8D]
You got quite a set-up planned there... I LOVE it!
MD
RE: patriot talk
Why go with retracts? I'm about to start on the wings but can't make up my mind which way to go. Retracts add weight and also those cutouts have got to add some drag for disrupting the airflow over the wing's surface but they raise the "cool factor" quite a bit. However, I can't help but wonder if they are all that much better than the fixed gear equipped with the thin racing type wheels similar to the ones on the Jett website.
decisions... decisions...
My Feedback: (50)
RE: patriot talk
Depends on the goal I guess... A lighter Patriot (without retracts-) with a smoother belly, and missing intakes will be faster than my Fatso Patriot with Air Retracts, and flaps- But I like those features so some day I can get my turbine waiver with it or a DF/OS-91
Seems to me that after READING alot about speed planes on here- the Patriot is not actually that fast... The ducted fans I have flown were noticeably faster, and I am sure my Whiplash will be much faster also- Let alone the Q-500 types, F3D (that correct?) pylon guys that run Hopped up Nelsons and Jetts...maybe even a glider [X(]
If however, you want something 100+ with WHEELS (retracts especially-) that looks great in the air the Patriot is a wonderful plane...It will also KE all day- makes the transition to ducted fans or eventually turbines much smoother than going from a slower sport type plane-
Cheers
Cheers
RE: patriot talk
maybe make them smaller, but i wouldent remove them. or make clear plastic covers so theres not that blunt edge.
if you put doors over the gear and use the hobico retracts above (since your plane will be much lighter than mine) it should still be low drag (note that having 2 metal rods hanging out the bottom of your plane is not what you would consider aerodinamic..
the cool factor is what makes it or breaks it isnt it?
i was still unesided on the covering, maybe another 3d flag (the one found here under tips)
or somthing with some noce pinstriped flames that are airbrushed on im still not sure.
figure i need to build it before relly worying about covering... ill look into the pnewmatic retracts though (how much eavier are they than the hoico?)
was figuring i could mount engine inverted and lead a tuned pipe under the fuse, will this not work? (im not sure on patriot dimentions so i dont relly no)
im not sure if id really want to land a plane this size at the speed it will be going w/o flaps on racing wheels, im theinking of a slipery landign with little control... but ive never used them so idunno, are they hard plasic or rubber?
i was originaly thinking of using the euro retracts that a couple people here mentioned as being good. but their site is almoast compleatly under construction and the spring airs have no pics of the full retract unit... (i like to see what i buy b4 i buy it) anyway, waht number springairs do u use? i think i remember someone saying 305's? maybe or somthing like it
RE: patriot talk
ORIGINAL: CBRC-Tom3rd
If you are after speed, you need low drag, and retracts will have much lower drag than fixed gear.
banktoturn
RE: patriot talk
thought i said that... not to mention, you cant build a patriot and not put retracts on it, all the other patriots would make fun of it... and it would never want to go into the air again and you would be foreced to lock it in the basment or move out of planet where they dont have retracts
ya no, im starting to think it would be faster to get a ticket and fly to the eruokit factory and order my retracts there rather than wait for their site to be fully updated to working order...
any one have an alternate vendor of eurokit retracts?
MD
RE: patriot talk
ORIGINAL: Balsa Master
FLAPS... am thinking about using the stock aileron and lopping off a few inches to make the flaps work from the trailing edge of the wing. Will that work ok or should I plan on making the flaps hinge down from under the wing?
My Feedback: (60)
RE: patriot talk
I guess it depends what DF y'all are talking about. I've owned over 10 patriots and I fly them routinely (have three flying right now). My fastest patriot is with a ys 45 no intakes with spring air retracts. It is much faster very noticeable than my Kangaroo Turbine jet with 18 lbs of thrust. Which then again is much much faster than my old DF F-15 and BD-5 and F-16.
Good Luck,
Sean
Good Luck,
Sean
RE: patriot talk
I have not ordered a Patriot yet, but could the wing ribs be cut down for a thinner faster wing & more speed. How about taking some weight out of it in the construction, how many ounces could be shaved by using contest grade wood, and other weight savings methods. The Jett 50 would be my choice of engine, as I don't see any better with a throttle. Thanks
RE: patriot talk
I have my wing 95% finished "all framed up" just need to run the air lines. Im appx 70% done with the fuselauge. I went with a YS .45SE with a Macs tuned pipe, so I could add a larger tank above the wing area. This will be my 1st plane with retracts. I had to modify my tank floor in order to get my B&D pneumatic nose gear unit to fit, but all looks good so far. I wanted flaps too but kinda got a little lazy so I decided to just add an extra servo in the wing and just program in flaperon mixing. Im not 100% sure just yet but I think I'm gonna go with the USAF Thunderbirds scheme. I'll keep you guys up to date. I have to admit alot of you guys have helped with your suggestions. Some of the suggestions were kinda obvious that I just didnt see due to Cranial Flactulance, and still alot of others were very innovative. Well,..... Thanks so far,......
FUZZ
FUZZ
RE: patriot talk
This is how I put an OPS 40 RI/RE engine into my patriot. You can fudge the landing gear off to one side and get the tuned piped down the other. I built the cowl to cover everything up. The canopy didn't look right so I moved it to the front and enlarged the rudder to make up for it. Hobbico mechanicals. I can recommend you go to a six volt reciever pack, as it will bump up your retract servo to about 20% more power. Helps fight the airstream better. It's been finished since this picture, and I finally got a decent camera so I'll put some pictures up next week. The drop tanks (yep,funtional) are still in primer until I put a couple drops on them and see if they hold up. I've thrown them across the yard and they tumble well, so they should hit softly.
RE: patriot talk
John A,
Thats a nice looking patriot,.....I look forward to hearing from you on how she flies. I think I will snap some shots of mine,....while its still in the bones.
FUZZ
FUZZ
RE: patriot talk
I have built five Patriots over the years....three had fixed gear, with speed wheels, and a Webra Speed 50, no problem with a 9-9 APC prop, and very fast... built the last one with retracts, using the Magnum 50 with pipe, weighed 5#8oz. At speed it sounded like a high pressure air leak... alas , the cornfield grabbed it after a high speed stall coming out of a dive... some advice, dont cover it in aluminum... ask me how I know..
CO
RE: patriot talk
ORIGINAL: eugene
Tooo far..too fast, disappeared in the sun and haze for an instant, thats all it took...in a split second, it was cuttin' the corn....
RE: patriot talk
Convertable patriot. The MDS 58 hauls @$$! Made this mighty fast. Shame i cant be bothered to put the retracts in yet....... Kicks @$$ though at the moment!
Canopy tore off today.
My Feedback: (50)
RE: patriot talk
Dave- Pretty good speed when parts of the aircraft decide to depart-
When my Patriot was still with us (Moment of silence here-) some times on takeoff, if I had to steer a little with the nosewheel, one of the tires on the mains would spin right off, leaving the plastic wheel in tact, and run off into the weeds... Never hurt anything just landed on 2 tires and one wheel-hub!
That just shows how fast that thing tracked down the runway with the Jett-50 I literalle wore out a set of nice tires doing nothing but taking off as straight as possible-
