My Whiplash prior to first flight-
My Feedback: (50)
Wow- I guess that RCU has fixed a glitch or two I can now start a thread- and/or post a pic!
This is really an amateur set-up compared to most of you folks for a Whip but I fly what I got Maiden flight last weekend was aborted due to gala force winds.... I also threw my MACS pipe on here after some people were laughing at my stock muffler-
Anyhow:
YS-45 MACS 7.5CC pipe
10x7 APC to start, 9x8 afterwards?
Hitec-645MG's on Elevons, 148 Throttle-
Shaker can paint job-
Well, have a good one all y'all!
Anyhow:
My Feedback: (12)
RE: My Whiplash prior to first flight-
Razor,
Don't hack off 3"!!!! That will be too much[X(] especially with the best starting point (9X8 APC) Remove about 3/8" at a time and test. I suspect by looking at the photo you'll end up removing 1.5 to 2"
It's better to be a little bit too long than any amount too short especially for initial shakedown runs.
Have Fun!!!
Have Fun!!!
My Feedback: (50)
With the "full-length" pipe should I start with the 9x8? I just wanted to make sure it had oomph on hand launch for the 1st flight-(10x7 or8)
My tach is a paperweight so I have not cut the pipe... yet- If y'all are sure that it will be 2+ inches I will go ahead and cut it prior to the first flight just to be close- and use a 9x8...
Thanks!
james
Thanks!
james
My Feedback: (12)
Razor,
I haven't flown a whiplash but since most of the people flying them are using 9" Props I would think that would be OK. A 10" prop would give you more acceleration from the handlaunch but would also have a higher torque & P-factor requiring even more right aileron on the launch. Talk to Chuck!
Start out with 17.5" (Glow Plug to end on converging cone, measured along the centerline) & 9X8 Prop with 15 to 20% Fuel. From that point shorten in small steps (1/4") with testing. You'll be able to tell when to stop. (When it jumps on the pipe at the last 1/8 of throttle or when you have to lean slightly to get it to jump on pipe but then when it does it wants to be richer).
I wouldn't do any pipe shortening until you get comfortable with the airplane! Like I said before being too long will cost you a few RPM's but it will run and carburate just fine. Not so with too short!
Be sure and give us a full report
