What to use to seal hing gaps
RE: What to use to seal hing gaps
If you take care when working on the control surfaces there should be little or no gap in the first place... anything left can be sealed with packing tape... if your tape is about 3 times as wide as the hinge gap with the control surface deflected that is enough... so I guess 2" tape would be fine on a quarter scale plane...
