Dust motor mount
Reply
Old 07-09-2002, 01:10 AM
basmntdweller
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Dust motor mount
I just got my DD. In looking over the plans, I notice the motor mount plate is only 1/8 ply. Is this sufficient for a Rossi 45? I've got some CF or I could glass it or should I double it in the engine mounting area with another piece of 1/8 ply?
Thanks,,,basmntdweller
basmntdweller is offline
Old 07-09-2002, 12:59 PM
JohnVH
My Feedback: (38)
JohnVH's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ill have to look at mine, But I built it by the plans and have had zero problems with it with only a BB.46
JohnVH is offline
Old 07-09-2002, 05:54 PM
jlong34016
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default dust mount
glassed mine top and bottom. jett fire 60 and pipe. lots of vibration. 10 flights and good as new.
jlong34016 is offline
Old 07-10-2002, 07:13 AM
rmorhan
My Feedback: (17)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i would leave the ply plate as is . 50+ flights on mine , ive had everything from a 25 on pipe to 46fx on pipe& it held up fine until... i was doing full throttle diving passes lower & lower , on my last pass (the lowest possible 120 mph +) whack!! the plane did a 40 ft high bounce deadstick. turned into the wind& landed sweet!! i could see the motor hanging & expected carnage. up on inspection found 1 prop with no blades& motor mount broken clean off at blind nuts (NO OTHER DAMAGE TO AIRFRAME) repaired in 1/2 hr, cut new ply plate & epoxied to old one. a breakaway motor mount makes sense on any plane with out landing gear. however on my new one ( jett ss40 powered ) i am doubling the balsa sheeted bottom with 1/64 ply( a couple dead stick landings on the asphalt runway made me wish i,d done this on the first ! )also i,m moving the antenna tube holes away from the firewall . ( i,ve seen a couple of dusts crack the 2 centre ribs at these holes. (ROUGH landings) any one else suggest further mods??? rob m
rmorhan is offline
