Launching a DD
Reply
Old 06-25-2004, 04:42 PM
hooaa
hooaa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Launching a DD
How should the DD be held, and pointed, for a successful hand launch?
Power is Jett 50 FIRE.
hooaa is offline
Old 06-25-2004, 07:37 PM
FlooredCOBRA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Launching a DD
I have launched by myself or with some one launching for me depending on day.
If you have someone launch for you I found best way is to hold mid way on LE of wing about where rib is. Hold nose upward about 35-45 degree and slightly slanted toward the right. It has a small torque roll to left when launched so that helps by launching with it leaning toward the right. That way it will roll over and stop when it is flat. Then just hit it WOT and have them let go. No need to toss I found that just by letting go it does much better for me.
If you want to launch by yourself cut down you your elevons about 1/4 in center enough for you thumb to fit. Then just hold with thumb between elevons and fingers under and launch same way. Up and to the right.
Happy flying!
FlooredCOBRA is offline
Old 06-25-2004, 08:20 PM
hooaa
hooaa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's the info I was seeking. Thank you. I have a helper. Should be fun!
hooaa is offline
Old 06-26-2004, 02:27 AM
C roundy
C roundy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: hooaa
I prefer to hold it by the thick silicone pipe coupler that I use. It is the perfect balance point for effortless starting and launching; And yes I did master every other possible way of (self) hand launching before I grew the cahonies to try this method, and come to this conclusion[8D].
Best Regards C.R.
C roundy is offline
