V-Tail Mixing
Reply
Old 06-30-2004, 05:51 PM
radiocontrol
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default V-Tail Mixing
I have ordered my first plane with a V-Tail configuration. (Viper 500). I have a computer radio that explains the setup, but the instructions aren't very clear. If set up properly, I assume that if I pull back on the right stick, both ruddervators will go up. If I push forward on the right stick, both ruddervators will go down. If I move the left stick to the right for right rudder, will the right ruddervator go up and the left ruddervator go down? Or vice versa? I'm confused! Also, what is the advantage of a V-Tail over a standard tail will rudder and elevator?
radiocontrol is offline
Old 06-30-2004, 06:34 PM
MikeMc
MikeMc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: V-Tail Mixing
For right rudder.
Right = down
Left = Up
MikeMc is offline
Old 06-30-2004, 06:49 PM
js3
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
RC,
Go take a look in the pylon forums. There are a number of posts on exactly what you're asking.
But to answer your question here, when moving the rudder stick to the right (for right rudder), the right ruddervator will go down and the left will go up AS VIEWED FROM BEHIND THE AIRPLANE. This is the opposite of how the ailerons operate. Remember that you're dealing with the yaw axis (not the roll axis) and it should become more clear.
You are correct about both ruddervators moving up when you pull back on the elevator stick.
There are several advantages to the V-tail config. First, there is less wetted area and one less surface for your empennage, thus there is less drag. Second, because the angle of the V-tail is greater than 90 degrees and depending upon where on the fuselage the V is mounted, draggy surface intersections are avoided. Third the elevator will never be blanked by the wake of the wing thus there won't be a "dead" spot in the elevator's responsiveness.
There are also disadvantages to the V-tail config. First, setting it up takes thought (until you're used to doing it). Second, it's a lot harder to build and set the correct angle of incidence. Third there may be roll coupling when giving rudder input.
That's just off the top of my head. Maybe others can think of more advantages and disadvantages.
js3 is offline
Old 06-30-2004, 06:52 PM
radiocontrol
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks MikeMc and js3. I appreciate your input.
Old 06-30-2004, 07:55 PM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The easiest way for me to remember, is that the movement will be the opposite of the Aileron.
If you hold the aileron stick to the right , the right is up, and the left is down.
For a V-tail, it is the opposite when you hold the rudder to the right.
daven is offline
