Problems with Rossi 61 RIRE
Reply
Old 07-05-2004, 05:22 PM
Evil Homer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Problems with Rossi 61 RIRE
I have a Rossi 61 RIRE which i am really battleing to get running properly, running 10x6 APC on 0 % fuel with 1 shim cannot get more than 13700 way i figure this should be up in the 18's.
Pipe is at about 250 at the mo, but not making much difference.
Anyone got info on which way the backplate should be mounted on as well as which drive hole to use on the rotary valve as this has been fiddled by previous owner and i dont have a reference to compare to!
Evil Homer is offline
Old 07-05-2004, 05:31 PM
ChuckAuger
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Problems with Rossi 61 RIRE
If it is a disk valve version, the carb should be at about 1~2 O'Clock looking at the backplate. The disk should be timed to where it opens just a few degrees after BDC, normal rotation, looking into the carb.
ChuckAuger is offline
Old 07-05-2004, 09:45 PM
r-c-guy
My Feedback: (37)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rossi's do like some nitro...
randy
r-c-guy is offline
Old 07-05-2004, 10:38 PM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
5% maybe... a 10x6? What are you flying?
Jeff- I was getting a little over 14K on a 11x7 APC on the Augered Rossi-60... Don't think I am getting it on the pipe properly, where would you recommend going from here prop-wise?
I could hack the header...
Razor-RCU is offline
Old 07-05-2004, 11:03 PM
ChuckAuger
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You will just have to tune the pipe and see what you get...a tach and a tubing cutter will tell the tale
Old 07-06-2004, 11:51 AM
Evil Homer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Actually i was hoping to go overboard and use a 10x8, but so far the proformance has been dismal to say the least so i have not migrated any further.
Going to see what i can do with the pipe and trim it a bit.
Old 07-06-2004, 12:38 PM
der_steuermann
der_steuermann's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
squid1,
I'd mount a fine-balanced 9*9 APC for pipe tuning purposes. Which pipe do you use? Are pics available?
If the pipe has a biggest diameter of approx. 42 mm then I'd start with 310 mm distance from the glow plug to the weld seam of the double cone or the deflector plate respectively. Then shorten the header in 5 mm increments until the rpms begin to decrease. That should happen at about 290 mm. 10% nitro should be OK.
Do you use pipe or crankcase pressure?
der_steuermann is offline
Old 07-06-2004, 12:45 PM
ChuckAuger
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: squid1
Something is wrong with it if it won't break 14K wit a 10X6
Old 07-06-2004, 05:01 PM
Evil Homer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am using crankcase pressure, current pipe length is possibly on the short side (cant measure it on a business trip at the mo), i am using a MAC pipe, think the measurement is about 260 from glow to "fat" section will take some pics when i get back, what kinda figures should i be looking at getting with the 10x6, i would have thought about 17k but could be way off the mark!!!
Old 07-06-2004, 05:56 PM
ChuckAuger
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You ought to be able to get better than 14K on a 10X6 with open exhaust IMHO.
Old 07-06-2004, 06:20 PM
der_steuermann
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Unfortunately 260 mm pipe length is too short for a .60 engine (even for a Rossi DF engine). As suggested above please start with 310 mm.
We don't know your speed frame yet, but in combination with your Rossi ducted fan engine a 10*6 sport prop is the wrong choice for speed. If your fuse is slim (same width as the engine) and the wing airfoil designed for speed application these pylon props should work fine for the first flights:
APC 8.75X9.25W (LP088925W) and
APC 8.75X9.5NN (LP08895NN)
Both props feature the 14.5 mm thick D1 hub being a must for your engine unloading significantly in the air. Static rpms should be in the 20K region.
If you purchased the engine used, did you check the bearings and the conrod for clearance? Ever noticed a loss of compression during operating temperature? Chrome plating & piston surface intact? I'd also check the exhaust timing. Maybe somebody's installed the "sport" liner instead of the DF liner [:'(]
