255 MPH DD NEED FOR SPEED NITROUS OXIDE KIT
GA
Well hi all…
Say you have the need for speed ?? Well I was at a fly in over the weekend and there was a guy there flying a DD on a mvvs 45 with pipe and get this a nitrous oxide injector kit on it that’s right nitrous!!!! He was clocking at over 255 throught the speed traps with it ..
He also was flying a Q500 same nitrous kit at well over 175 on an LA40 … the kit is easy to install and can be moved from one plane to another at the field
If you would like more info Email [email protected] I can tell you how to get the full kit they are selling for only $120 everthing you need is in the kit to ramp up that speed plane
Have a great one just thought you all might like to know about this one
Rob
Rob
GA
RE: 255 MPH DD NEED FOR SPEED NITROUS OXIDE KIT
255? how much higher did that engine spin over max rpm rating to get that number?
How would you prop that? load it like normal or slap on a thick pitch so when you do decide to hit bottle the extra power would be put to use. Only thing is it would lugg around off the juice.
I just dont see much fun or point in bottle on a plane... a few flyby squirts and back to stock form. Then have to go refill bottle again.
I would rather just spend a little extra and buy and engine that perfoms.
Seriously, everybody would agree that nitrous oxide is the wrong strategy to reach that kind of speed. Why push an ordinary sport engine for a few seconds above its structural limits risking a blowing connecting rod etc? When using a non-speed engine like the MVVS .45 I assume the DD pilot did also mount a regular APC pylon prop potentially hurting somebody when throwing a prop blade. That would not be safe!
Now, let’s imagine the following setup:
DD airframe + MB .40 FAI engine + F3D pylon prop
http://home.kabelfoon.nl/~fiorimet/Index.htm
Being the current most powerful F3D engine the MB .40 spins the 7.2*8” CF prop at 30 K static. Even after unloading during a powerdive it’ll be tough to reach 255 mph with a competition F3D airframe. So just recall mounting that engine/prop combo on a DD. What do you think, will the DD airframe be aerodynamically superior to a competition F3D airframe? And do you really accept the idea that a nitrous oxide doped MVVS .45 exceeds the performance of a stock MB .40? Well, I don’t. Actually I do mistrust the speed numbers given in post #1.
Referring to several car discussion forums some R/C car drivers used nitrous oxide injection for fun purposes so far. The modern high performance .12 to .27 sized R/C car engines do withstand these short-time loads much better than our relatively "slow-going" aero engines (including JETT, ROSSI,...). You won't do your aero engine a favor while injected by nitrous oxide.
A much more consistent way to gain serious speed has been described e.g. in the thread
Few variations of planes? (Post No. 13)
http://www.rcuniverse.com/forum/m_18...tm.htm#1815237
In the past I performed some extensive testing on different own airframe designs to prove for best possible aerodynamic solutions leading to satisfying speeds.
Result: Besides the project-oriented optimal engine/pipe/prop combo it is the airframe & airfoil that in most cases needs "research work".
Together with a knowledgeable buddy we also designed different carbon speed props. To achieve the target speeds the goal was to increase the degree of efficiency (also of the inner prop part) and to minimize losses (e.g. at the prop tips due to transsonic or supersonic speeds).
To come back to the original topic: Don’t waste your money on gimmicks like nitrous oxide injection but rather safe your bucks for a true high performance engine effecting long lasting pleasure. And grab a pencil and design your own custom speed plane.
In the long run that’ll give you substantial satisfaction and success in terms of what you define as „ultimate speed“.
My Feedback: (19)
OH
LA40 powering a q-500 at the same velocity of a very competitive AMA 428 Q-500 ?
Can't say it didnt happen..... I wasnt there. In this world anything is possible. Lets just say a large number of years of experience and engine knowledge has tossed up a bright red flag.
The last time I recall seeing a radar gun reading of 255, the end of the nitrous injector tube was inserted into my left nostrile....
MN
LA 40 at 170 mph
Now thats funny. I doubt the bushing in that engine could handle close to 20,000 rpms, and thats what you'd need to be turning a 9 pitch prop to hit 170mph on a Q500.
It sounds like fun to me. I don't care how well made the "world class" bottom ends are, any engine that is pushing 255 MPH will need periodic changing of the rod and close inspection of everything else. I see no reason why a bushing engine couldn't take 20,000 with enough caster oil. If a guy is handy it isn't that hard to whip out a batch of hard aluminum rods. I would plasma coat the tops of a dozen pistons, and that should be an ample supply for a good amount of demo flying. I can remember a time when an average guy could raid the local wrecking yards for hemi parts and run TOP FUEL [successfully], so I totally understand the logic behind hot rodding an OS LA, I sure wouldn't want to do it to my RO$$I[X(]! As far as the AMA is concerned with this, I just wouldn't invite them to come along.
My Feedback: (50)
I would just be happy getting my K&B 7.5CC to run properly---
And IF I were going to attempt 250+ I would use the composite WHIPLASH rather than a DD- I can just see one little corner of monokote starting to come off [X(] the DD
I think a DD that is covered with a light rip stop like MICAFILM would hold up. From what I hear the WHIP is quite a bit heavier than the DD [after painting]. Multiply the extra dead weight by the G forces at 170 MPH and I will bet the DD performs much better all around. I would send the plane up first with a 7.5-10 prop and work my way back from there. Without seeing a system, I guess the nitrous could be introduced along with a seperate fuel supply that is bladder fed through a remote needle valve. A servo would have to be dedicated to controlling a fuel line pinch. I can't wait to actually see how this guys' system works! Supercharged engines don't need radical timing to perform well, another good reason to choose a mild engine for this.
IL
"I don't want to start anything, but doesn't the AMA code forbid the use of gaseous boosts?"
AMA? What do they have to do with it?
9" pitch to flow a Q5 at 175 would take at least(min buy my calc and exp) prop turning 25K ,,, and it just clarify that would be a pitch speed of 213. it might be possible to get the ship moving 175 with that kind of pitch but would take more diameter to get the thrust to get there. (straight and level) I never dismiss a claimed top speed untill it gets unreasonable math wise. From there, I just need to see it to believe it. And sometimes the math is outdated.
I would like to here more from Comotech but it looks like hes bowed out of this thread he started
BTW,, the MVVS would have to turn 10" pitch 35K just to get the DD to 255. ? is it possible?
thats kinda be hard to make a plane strong enoough to take that kind of power. youmay want to go for the twin engine design instead to balance out the trim. i have another pic, same hanger, with about 10 engines.
original: iskandar taib
Methinks there's a WEE bit of a calibration problem here. F3Ds don't go that fast.
In 1999 we clocked 229 mph with a F3D airframe, the old style RIRE MB .40 engine and a 6*9 CF prop. I am convinced when taking the actual MB .40 FIRE engine combined with one of the actual top end F3D airframes (e.g. the German DAGO RED INNOVATION) terminal speeds will end up to approx. 240 mph after a powerdive...
ORIGINAL: Dave_Gherardini
But hey, the guy is running an MVVS on nitrous for heavens sake! Probably turning an APC 13x13 at 20,000+...
My Feedback: (540)
ORIGINAL: comtech001
Well hi all…
Rob
Well hi all…
Rob
GA
Yeah funny how some people go about advertising things. The fella that started this crap posted then left post.
He was at a fun fly spectating this NOS system and has all the specs MPH numbers and an e-mail address to contact him to purchase. It seems that if he was trying to make a Buck he would fill in the blanks a little and answer some questions. This thread is about as anoying as a POP-UP that says "you won 60'' plasma TV."
Plain old BS.
Plain old BS.
