Engine for F16N
Reply
Old 07-17-2004, 03:10 AM
Dave03B
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Engine for F16N
As many of you will know, I have a CBM F16N with a Webra 91 in it. This is needing an 11x8 prop which leaves b***** all ground clearence. Now, i would go for a YS 45 but I cannot easily get hold of one here in the UK. So what engine will do equally well? (that i can get hold of)
What prop sizes are people finding work good with this plane?
Thanks for your help,
Dave03B is offline
Old 07-17-2004, 03:13 AM
Dave03B
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Engine for F16N
What about something like the OS 46 AX??
Dave03B is offline
Old 07-17-2004, 03:53 AM
angelrcdesign
My Feedback: (40)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How about a weston .50 V1 I'am sure you can get one out there .
angelrcdesign is offline
Old 07-17-2004, 03:59 AM
Dave03B
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just bought one of those for my MagnumR! But that will go in my magnum
c'mon! nothing else?!
(if i can get £170 from selling a webra 91 and an MDS 58 then good(i'll buy another V1), but i doubt that i can[&o] )
Thanks for giving me my first option,
any more out there??
Dave03B is offline
Old 07-17-2004, 09:35 AM
AirGar
My Feedback: (7)
AirGar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave,
You have a 90 size motor in it now, and you want to replace it with the same size that will swing an 11x8? Not quite following you....
The Jett 90L I have on my F-20 has an APC 11x8 up front...in fact, that's the ONLY prop that motor has ever seen.
The Jett 50's swing 9x8's and 9x9's if your looking to downsize.
What's the flying weight?
You can't go wrong with the Jett line of motors.
Gary
AirGar is offline
Old 07-17-2004, 09:38 AM
Dave03B
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm looking for an engine thats comparable to the YS45. And that will swing a smaller prop.
what size prop is most suited to this plane?
Dave03B is offline
Old 07-17-2004, 11:08 AM
AirGar
My Feedback: (7)
AirGar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well then......top choices would be:
Jett 50
West 50
The above, are both a little better in performance than the YS 45, IMO.
Next in line would be the YS 45....
Other motors to consider is the MVVS 49, and the Webra 50 (the West 50 was derived from the latter) (I, personally don't have experience with them, but I have heard nothing but good!) Obviously, these are not going to perform like the first 2-3 mentioned, but are good and cheaper alternatives.
Gary
AirGar is offline
Old 07-17-2004, 08:52 PM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You need a YS-45 >>> .
Try a search--- You will find EVERYONE recommending the YS-45RE, Macs tuned pipe 7.5/8.5CC w/APC 10x7/8-
With the fuel tanks being 3 feet from the engine you need something pumped- (Preferrable RE so the pipe is hidden in the fuse.)
I have one but it is SE
Razor-RCU is offline
Old 07-18-2004, 03:20 AM
Dave03B
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've got a perry pump connected to my current engine thats in there.
does that help my situation?
so for being a bit dense in this topic.
Dave03B is offline
Old 07-18-2004, 07:54 PM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I guess if you have a reliable pump the Jett-50 would be the way to go--- A gent. was flying one of these at our field recently (with a YS-45) and it was pretty quick.... Not much for vertical but they sure look cool!
Wasn't yours nose heavy with the Webra on-board?
Old 07-19-2004, 04:01 AM
Windwalker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave-
Before you drive yourself nyuts trying to swap that engine, try a 10x9 or maybe a 10x10 prop.
Tach it and the Webra will tell you which one it prefers...
Good Luck!
WW
Windwalker is offline
Old 07-19-2004, 07:41 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Razor........weren't you looking to sell off an YS45 ??
The YS is probably the best choice if you are looking to replace the engine.
The Jett 50 has been used on a number of F-16N planes with good success, but each required either a perry pump, or an revised fuel system installation and a 2 oz header tank right at the firewall. The Weston would work with the same conditinos. The advantage the Jett 50 has is you can run the side exhaust version with the muffler, and get nearly the same performance the YS RE can supply. Most guys were turning 9x8 or 10x6 pusher props on the F-16N installation.
In the short term, you may try the other props suggested. I know, its hard to find pusher props in the correct size. But even if you simply take your 11x8 and cut it down a bit, you may find some improved performance. APC makes a 10x8 P prop that would probably work well too. The Webra 91 is fairly high timed, and does not at all mind turning up a bit Let it unwind.... RPM is your friend with that plane... the prop is in dirty air to start with. If you are running a pipe, you will have to shorten that up a bit when using the smaller prop.
Bob
bob27s is offline
Old 07-19-2004, 08:57 AM
Flyboy Dave
My Feedback: (21)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree....prop down the Webra, and scream it for all it's worth. I don't think
the 45's and 50's will provide the thrust you need for that plane. I had one
with a brute OS 1.08 FSR in it !
FBD.
Flyboy Dave is offline
Old 07-19-2004, 07:00 PM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, I was WILLING TO LOAN it to him!
Flyboy Dave is talking about the Cermark F-16 not the CBM F-16N (He must be painting his hot-rod and inhaling a bit...)
YS-45
Jett-50 pumped
West-50 pumped
etc..
Same advise many posts later---
Old 07-19-2004, 09:22 PM
vicman
My Feedback: (10)
vicman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Razor, I thought you were going to loan it to me?[]
vicman is offline
Old 07-19-2004, 09:44 PM
vicman
My Feedback: (10)
vicman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave,
Check the F-20 club, the last two pages. Razor and others gave me some good advise about this plane/motor combination.[sm=wink.gif]
vicman is offline
Old 07-19-2004, 10:27 PM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Whomever needs it- Sounds like the MVVS-45 will be more than enough for the F-16T you have...
Keep us posted-
Old 07-19-2004, 11:36 PM
Flyboy Dave
My Feedback: (21)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Razor-RCU
Right on, James....[sm=stupid.gif]
....I was thinking about the Cermark F-16 FTP. ( flying telephone pole )
....back to the drawing board. ( I gave the plane away ! )
FBD.
Old 07-20-2004, 01:59 PM
Dave03B
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Razor-RCU
is nicely balanced
Dave03B is offline
Old 07-20-2004, 02:01 PM
Dave03B
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'll try an get hold of a 10x8 P Prop. thanks for all your suggestions and advice. I'll keep you posted.
Dave03B is offline
Old 07-20-2004, 02:02 PM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I meant tail heavy... oops
Old 07-20-2004, 02:47 PM
Dave03B
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
right then chaps (chapess' if there are any) suggest my weapon. I have a distributor locally of apc P-props and can get;
which one for my Webra .91?
9x6
10x6
10x7
10x8
11x6 (too big)
11x7 (too big)
14x6 (too big)
Dave03B is offline
Old 07-22-2004, 03:21 PM
Dave03B
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
so, which prop?
Dave03B is offline
Old 07-22-2004, 03:31 PM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
of those available
run the 10x8
bob27s is offline
Old 07-22-2004, 03:33 PM
Dave03B
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks. 10x8 it is
Dave03B is offline
