Go Back  RCU Forums > RC Airplanes > Extreme Speed Prop Planes
Reload this Page >
PROP FOR OS VR ENGINE ON A DIAMOND DUST
Old 07-24-2004, 07:47 PM
snowboat
Default PROP FOR OS VR ENGINE ON A DIAMOND DUST
I have just purchased an OS VR engine and am puting it on a diamond dust. The os VR is a discontinued pylon racing engine. The rpm range of this engine is 19000 to 25000 rpm. It looks to me to be very similar to a ducted fan engine. It has rear exuast,and a rear mounted carb. I am useing a MVVS GRRT tuned pipe on it.
I broke it in with a 9*4 prop and could peak it at 21000 rpm
What would be the best prop range for use in a diamond dust.
Old 07-24-2004, 07:55 PM
ChuckAuger
My Feedback: (12)
Default RE: PROP FOR OS VR ENGINE ON A DIAMOND DUST
I ran a 7.4 x 8.25 APC carbon fiber pylon prop on a 46 VRDF on a Dust, I'd think the VRP would be happy on it as well.
Old 07-24-2004, 08:30 PM
combatpigg
combatpigg's Avatar
Pick up a 7.2-8.6 APC while you're at it. Launches my DD with no problem.
Old 07-25-2004, 04:51 PM
snowboat
MY engine is a .40 size. Would the props you selected work?
Old 07-25-2004, 06:07 PM
combatpigg
combatpigg's Avatar
Hi SNOWBOAT, I think so, the 7.2-8.6 is a .40 pylon prop. My os .32 on a 90% DD is spectacular with it, better than the 8-8 APC, but the launches aren't as effortless. The launches are still good, but at a shallower angle. If your .40 is more powerful than the .32SX, you will get impressive results if the prop hooks up with your planes' weight and drag. My 90% scale, scratch built DD weighs 2.5 lbs dry.
Old 07-25-2004, 08:23 PM
ChuckAuger
My Feedback: (12)
ORIGINAL: snowboat
The 7.4 x 8.25 APC carbon fiber pylon prop I ran is a 40 sized pylon prop. It was designed to run on 40 sized pylon engines. It had plenty of thrust to launch a Diamond Dust.
Old 07-26-2004, 07:40 PM
snowboat
The 7.4*8.25 Carbon prop seems to be dicontinued on the APC website. Where can I find one?
Old 07-26-2004, 07:46 PM
ChuckAuger
My Feedback: (12)
www.pspec.com Go there, get the ph #, ask for Dave, he'll fix ya up. Tell him what you have, he might have some different recommendations. He is a past champion pylon racer.
And FWIW, I don't think I've ever seen this prop on APC's "Prop List".
Old 07-27-2004, 02:45 AM
dioncuda
dioncuda's Avatar
ORIGINAL: snowboat
[link]http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXHCG3[/link]
Try this.
Old 07-27-2004, 10:31 AM
MyWay
ORIGINAL: snowboat
Sounds like you need to try a different tuned pipe. That engine should blow a 9/4 prop apart. Try a 9/6 with no header attached and see what rpm you get. Then put your pipe on it and see what the rpm is. I would bet you lose about 1000 rpm or more.
