Prop Jets
Reply
Old 07-23-2002, 09:51 PM
JimmyA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Prop Jets
I am looking to get a prop jet to replace my Patriot. I am thinking about the Cermark F20 60 size ARF but I can't get any info on how fast will it go? I am planning on using an OS .91 FX. I would like to get a prop jet that will go about 100MPH - 130 MPH what do you guys think?
Jimmy
JimmyA is offline
Old 07-23-2002, 11:04 PM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Search!
Try a search on "propjet" or "Patriot" etc. There are many threads about these high performance beauties!!
I have a Patriot ARF with an Irvine 53, should have a maiden flight this weekend!!
Why not try the CBM F-16N?
<< (heres' mine)
Razor-RCU is offline
Old 07-24-2002, 01:05 AM
Cyclic Hardover
Cyclic Hardover's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Prop Jets
I am 3/4 through my 60-90 size Cermark. I stripped the Red off completely and recovered in Monokote "Charcoal" with white underneath. I installed the Jett .90 in mine. if you go with the 91fx, you ought to install the Ultra thrust muffler also.
* I have the Little F-20 also and it is in the 120mph range. The bigger Cermark with the right engine will be around the same. There are a few modifications which are a must or tthe plane may only last a few flights before the damage show itself.
Cyclic Hardover is offline
Old 07-24-2002, 01:14 AM
JimmyA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Re: Search!
<< (heres' mine)
How did you get that Patriot ARF kit? BTW, Is there a web site for the CBM F16?
JimmyA is offline
Old 07-24-2002, 01:16 AM
JimmyA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Prop Jets
What do you consider the right engine for the Cermark F20? If it will do 120 MPH with the Jett .90 then that is what I will use! BTW, could you tell me more about the modification I need to do?
Jimmy
JimmyA is offline
Old 07-24-2002, 01:25 AM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default cbmjets@aol.com
They make several pushers including the F-16N the FA-18 Hornet, smaller F-15 Eagle and the A-10 also..
I got the ARF Patriot from WARJET (right here on RCU..) I have seen a couple on e-bay also..
Keep us posted!
and yes, use the JETT!!
james
Old 07-24-2002, 01:31 AM
Cyclic Hardover
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Prop Jets
The engine mount area is already built. Instead of installing the traditional engine mount, it is already their using hardwood rails. This is okay I guess but I epoxy glassed the entire inside of it all.
*Two of my close buddies have this engine on DC F-18s. It will flat tear right off from torque if you do not glass it up. Retract mounts again won't last long at all. My guess is only a couple flights unless you beef up the mounts.
*Elevator servo. is a single servo attached to the stab with little blocks. Very stupid. A guy somewhere here had one which crashed on a maiden flight because the servo broke lose. I expoxied my servo right to the stab itself, then glassed around the bottom also. That sucker is not coming off! Not much room in their either. Get some sort of a low profile high torque servo.
* Since i decide to recover , I also dabbed a little epoxy on each rib just for aggravation. Overall it is a good plane. I just don't like red. Also our stats here at 5000ft fall short of what you'll get in Florida. I boast 120mph for my DC F20 but that is as best you'll get here with a 17% overall loss in peformance. I know guys at sea level with the same setup getting 150mph.
Old 07-24-2002, 01:38 AM
JimmyA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Prop Jets
Cyclic Hardover,
Thanks for the info. I also don't like the red color on that plane so I am going to be recovering it as well.
Jimmy
JimmyA is offline
Old 07-24-2002, 01:47 AM
Cyclic Hardover
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Prop Jets
Here is the color scheme I used
Old 07-24-2002, 01:49 AM
JimmyA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Prop Jets
Very Nice. I think I might be covering it in a Thunderbird scheme. Not sure yet.
Jimmy
JimmyA is offline
Old 07-24-2002, 02:52 AM
Noflyzone
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default How fast are we all going
This seems to be on most guys minds, so here's a really easy formula to guestimate air speeds without any measuring device at all. It is: RPMxprop pitch in ft. ( ie a 9" pitch prop would be .75ft instead of just 9) x60 divided by 5280.
Example: Say your engine turns a 9" pitch prop at 20,000 rpm
Using the formula:
20,000x.75x60/ 5280= approx. 170mph.
These numbers deal directly with the theoretical max speed based on prop pitch only and tend to be a little low since motors unload in flight raising rpm's and twisting of the prop causes pitch increase. (Although the pitch increase in usually negated by loss of efficiency due to changes in prop dynamics.) I hope this helps most of you guys out there that are tired of guessing the speeds of their planes. Drag is also not figured in the above calc...
Dan, Aerojet Composite Models
Noflyzone is offline
Old 07-24-2002, 09:13 PM
Cyclic Hardover
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Prop Jets
Back in the early 80's the Thunderbirds were using T38's i think. Not sure if you are aware the T-38 is the 'Grandpa" of the F-20.
T-38, F-5, F-20. Anyways, go find a picture of it to go by.
Old 07-24-2002, 09:18 PM
JimmyA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Prop Jets
hmm I wasn't aware of that. I am going to look for a picture of it. Thanks
Jimmy
JimmyA is offline
Old 07-25-2002, 01:00 AM
Cyclic Hardover
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Prop Jets
Heres another "diddy" for you. Like I said earlier, first was the T38 which was a trainer in the late 50's, Then they thought it would be a neat fighter, so with a bit of cosmetics it became the F-5. Then in the early 80's Northrop wanted to compete with the F-16. They turned it from a twin engine to a single. The ass end gives this away*
This brings us to R/C. The DC F-20 is really an F-5. Although a sport scale plane, again look at the backend. The Cermark is the true F-20 with a single exhaust. Nothing wrong with either one. Just food for thought.
Old 07-27-2002, 04:04 PM
Flyboy Dave
My Feedback: (21)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default JimmyA
Look in this forum, under Patriot Drivers...
Look at the elevator mod...
I'm the guy who's F-20 crashed on the first flight when the elevator servo came loose.
Also, I'm sorry to say this...but you will be Disappointed in the performanc of the plane with the O.S. .91FX. They just "don't crank". If money isn't a problem...get the Jett 90.
Also, the retracts that come with the plane are junk...Get the Robart #609 H.D. mechs., their only like $40. The stock ones have prob. with the "axles"...they twist all the time, and you'll be dragging the wheels side-ways all the time.
The Robarts come "long", and you have to heat, and bend the strut for the axle, the cut off to size for the wheels.
However, the struts are thicker, and eliminate all the twisting problems.
Also...check in the back where the elevator torque rods fit onto the stab.<<< Mine was real weak there...I added some thin ply to the area to keep it on !
Keep the canopy out of the sun, at all times when not in the air...IT WILL MELT !! (too thin I guess). Also...put more hinges on all surfaces, and trim-tape ALL the hinged surfaces.<<<
I'm real curious about the new Magnum .91 2/stroke. BTW...I have two buddy's that fly 'em too...we compare notes...
Here's my pair...the 40, and the 60 Cermarks. I have the F-16 also.
( OOPS, I re-sized the pic, and messed it up )
Flyboy Dave is offline
Old 08-08-2002, 01:46 AM
emenot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Prop Jets
Check out http://www.zyworld.com/balsacabin/Page3.htm
The SU37 is SWEET!!!
emenot is offline
Old 08-08-2002, 02:22 AM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Wicked!
That SU looks wicked, but I need more info. Any reviews or pics out there...?
Call me when they make an ARF, or when you build it and wanna sell it..
james
Old 08-08-2002, 03:39 AM
emenot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Prop Jets
I am still debating, it cost close to US$150.00 landing it to the U.S. and then building it. This is going to take some effort. I don't think they are going to ARF it :-(!!!
emenot is offline
Old 08-08-2002, 03:53 AM
Flyboy Dave
My Feedback: (21)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Star Wars ???
You buy it, build it, and fly it....I'll watch....
Until then, I'll be stickin' with the "trusty"...F-20...
Dave.
Old 08-08-2002, 04:48 AM
emenot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Prop Jets
I have a F20 but not quite impress with the look due in part its not a very scale looking plane. But scratch build don't sound fun to me either, what a dilima :-0 ???
emenot is offline
Old 08-08-2002, 10:36 AM
jlong34016
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default demon
how about that demon further down the page?
jlong34016 is offline
Old 08-08-2002, 03:22 PM
emenot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Prop Jets
To go that kind of speed, I think you should go get a Q40 and a Nelson and a big field with 20/40 eyesight and a very good pilot. Its also good to become an AMA member first!
emenot is offline
