First Dust ready for a spin...:WOOHOO! :D
Now let's hope weather and work cooperate!
I originally intended to put my West .50 in it, but after putting everything on the scale I opted for a Webra Speed .32.
The plane comes in at 1135 grams (roughly 2.5 lbs) dry with 2 Hitec 605 servos, one Hitec 85 and an 800 mAh battery. Should be a blast at this weight.
The little Webra has a Jett Stream muffler, a Dynamix carb and turns an APC 8x8 quite happily.
It won't be a speed demon, but I hope it will be a great plane for an "up close and personal" kinda flying style.
The only real modifications I made were the use of "real" hinges, and glass fibre pushrods instead of steel (much lighter and stiffer).
The checkered film was a bit of a challenge to get down without too many visual flaws. I didn't get it 100% correct, but it looks ok.
RE: First Dust ready for a spin...
This thing is fun!
Like I expected, not a speed demon... but still good for something like a 125-130 mph I guess. The little Webra turns the APC 8x8 at about 17000, and it unloads very good in the air.
Didn't have to trim anything! It just flew right out of my hand. I just released it almost straight up. It rolls slightly to the left due to the torque, but then it picks up speed, and just keeps on going.
I maidened the plane during a 30 minute break in the funfly competition.
After a flight or two to get used to the handling I brought it down to the deck for some "banking and yanking"... and I had a crowd... I love it
There were like 15 people asking what that thing was... what engine... what's that exhaust... what prop... how fast do you think it's going...?
After today, I don't think I will ever put anything heavier on a DD than this Webra .32. This thing needs to be light.
The only downside is that I'm quite sure this plane is not going to last long. It is just too tempting to pull off some crazy stuff, and that is bound to go wrong sooner or later.
But if this one goes in, I WILL get another one. In fact, as of today, I think I will never be without one...[>:]
ORIGINAL: Rudeboy
Yep, the DD is good for a real rush and a big grin. It is hard to beat for a crowd pleaser. I however have had two and could not imagine it with less then a Jett 50 [>:]. My second one came out at 2 lbs and 12 oz mt and it seemed plenty light for over 500 sq. in. of wing.
ORIGINAL: Mike Connor
I'm already thinking about a second one... same power plant, but a couple of light digital mini's on the elevons, and a super light battery (perhaps lithium with a regulator)...
With proper hardware it should be possible to bring this thing down to close to a kilo.
My Feedback: (19)
OH
Glad you are having fun Rudeboy!
The nice thing about a Dust over the pylon birds........is that people dont expect you to make left turns all the time
ORIGINAL: Rudeboy
With a piped Jett .50...? WOW! What hardware did you use...?
