Shrike .40 first flight question
Reply
Old 08-30-2004, 12:00 PM
yee-ha
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Shrike .40 first flight question
Hi everybody. I am going to be finishing a Lanier Shrike .40 pretty soon. It has a Tower Hobbies .46 with the standard muffler and a dave brown aluminum spinner. I am looking foward to going fast! I have never flown a airplane of this nature before and am wondering what I should expect on the first flight. I consider myself to be a somewhat experenced pilot and have flown some airplanes that I considered to be pretty fast. (Mostly overpowered sportplanes.) However, they were no Shrike!! Being that the airplane is so short coupled, is the elevator really sensitive? Anyway.......The shrike is an experement and I am hoping that it lasts longer than a few seconds. Advise?
yee-ha is offline
Old 08-30-2004, 01:59 PM
Zpat
Zpat's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Shrike .40 first flight question
A friend of mine let me fly his LA .40 powered shrike and it was making a funny noise. I shrugged it off as being the silicone exhaust diverter. When I bought it down low for a high speed pass that funny noise was the wing in flutter. I handed the transmitter back to my buddy just before it went in. There was minimum damage. Aileron servo stripped.
After investigation it was found that the aileron linkage ( 1 servo and torque tubes) was a very sloppy installation.
Zpat is offline
Old 08-30-2004, 02:31 PM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Balance it per the instructions, and keep the control throw reasonable.....and you will have no problems with it.
It is a very smooth flying airplane.
You have a throttle. Use it for a while if needed. The plane will fly off of hand launch at half throttle.
Take the time to double check all of your linkages, and be sure to seal the control surface gaps.
Enjoy!
Bob
bob27s is offline
Old 08-30-2004, 02:35 PM
yee-ha
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what do you seal the gaps with? Thanks for replying.
yee-ha is offline
Old 08-30-2004, 02:46 PM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I typically use the same covering material used on the rest of the plane. Or, you can use simple clear tape.
bob27s is offline
Old 08-30-2004, 03:03 PM
Mike Connor
Mike Connor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: yee-ha
I put well over 100 flights on mine and the air frame is still good. I agree with Bob that balancing it is very important. I extended the hatch back so I could put the Batt in the very rear of the fuse. The Ailerons are more likly to be too sensitive then the elevator.
Mike Connor is offline
Old 08-30-2004, 06:01 PM
Cyclic Hardover
Cyclic Hardover's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ah one note here is on the elevator. Max throw will be needed basically for landings. Frankly you can't get enough and make your approachs shallow or it will pancake
Cyclic Hardover is offline
Old 09-07-2004, 02:12 PM
Douglashimself
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Take care to seal the leading edge really well or better yet wrap the covering well over the leading edge. I was doing high speed passes from a split S when the covering exploded off the whole left side of my Shrike. It was like a gun went off. Thank goodness the wing is sheeted 1/4 of the way back and the bottom half did not come off. It tried to run me down but I was able to land safe.
Have fun.................and keep on your toes
DH
Douglashimself is offline
Old 09-07-2004, 02:45 PM
SilverEagle2
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I built one and it sat engine less until my uncle found a 1972 OS-MAX H in his basement. Has been one of my favorites for several years now. It really scoots along. I echo the sentiments on the balance. I use the recommended throws but find if I pull to tight of a loop, it will snap out. So be careful there. The initial hand launch is a bit scary, but once you get a hang of it, you will be fine. I also run 30% fuel so I get a smoke trail just in case as this bird moves. Of course I run 30% in most everything I have.
Also, make sure you have a big contrast from top to bottom. You can get disoriented fast with this one.
Just hang on and have a blast! Great kit for the $$$
Jason
SilverEagle2 is offline
Old 09-08-2004, 03:52 AM
acr007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is my Shrike 40 with a JEN 56 (A 40 that thinks its a 60) with a tuned pipe.
Flies well but I advise 50% dual rates on ailerons and 50% expo and 50% expo on elevator as the controls are touchy and respond to the smallest input.
Its a blast to fly and have put a 10*9 on mine to push the speed.
I use carbon rods for all rods and two servo's for ailerons as you can use your mix settings to add in flaps on the alierons which if mixed with elevator can slow you landing speed to a slow speed but I mainly fly it fast and furious and land fast as you tend to lose elevator as you slow down.
I also fiberglassed all the fuse and the blue area as the fuse is the weakest point in the construction. Added rear hatch for battery and sheeted the stabilizers as big lump of lead on the front. On the next version I will shhet the wing to R3 so I can mount the servo holders to reduce drag on control rods.
A very smooth plane to fly.
acr007
ID:	171316   Click image for larger version
acr007 is offline
Old 09-08-2004, 01:40 PM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey Jason....
nice looking bird !! I like the color scheme.
Bob
bob27s is offline
Old 09-08-2004, 02:38 PM
SilverEagle2
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, Looks great in the air as well!
Wish I had a Jett 50 on the nose though
Jason
Old 09-21-2004, 03:17 PM
canardlover
canardlover's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Howdy, here is a swedish version of Shrike called Vildkatten(Wildcat) designed by Nils Hollman in the late 80ies. Found mine dirt cheap at a swap market, fixed it up and fitted a piped MVVS.45 which gives lively performance. Can be handlaunched or started from a dolly. Small foreplane is fixed and claimed to produce a vortex to aid low speed performance.An excellent flier.
Nice thread, hope it will be revived now.........Cheers/Harald
canardlover is offline
Old 10-11-2004, 05:36 PM
Mustang Fever
Mustang Fever's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was just wondering how your first flight went. I flew mine today, first time, with a Tower 46. I was very scared, because the airplane was about a pound heavier than they said it should be. It really staggered for a bit on every hand launch, but flew very well when up to speed. I took the Tower 46 out tonite, and substituted an OS 40 LA. Weight went down by at least a half pound, and there is still enough punch to go vertical. Can't wait to try it.
Like the guys say, approaches must be fast and shallow, otherwise you run out of elevator trying to keep the nose up, and she splats in.
More fun than I've ever had. What a blast.
Mustang Fever is offline
Old 10-14-2004, 01:35 PM
El_Guapo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Has anyone ever put a landing gear or retracts on a Shrike 40? I'm asking because I'm thinking of building this as a 4th plane after getting comfortable with my Sig Kougar. Problem is that I don't have a place with a smooth enough surface to do belly landings - either very dry/rough grass or pavement, neither of which would be very kind to the model...
Jacek
El_Guapo is offline
Old 10-14-2004, 10:49 PM
LGM Graphix
My Feedback: (22)
LGM Graphix's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are some pics of mine, my biggest complaint with them is they all come out nose heavy, mine could use a couple more ounces in the tail but I don't want to make it any heavier.
LGM Graphix is offline
Old 10-14-2004, 10:55 PM
SilverEagle2
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Show off!
Old 10-15-2004, 11:38 AM
canardlover
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jeremy, WOW..great airbrush technique you have...!! Well done - I´m really impressed.
Yes, the swedish Wildcat (post#13) also comes out nose heavy so I had to place servos, batteries etc.. as far back as the fuse will allow to avoid lead weights. That did it for me. You could also replace the muffler with a full length pipe to move CG a bit further back. Good luck..!
BTW, do you ever use water based acrylate emulsion paints when airbrushing..? Have seen that described in articles but not yet tried it.....Cheers/Harald
