AKM SU-27 Flanker-Does Look Good
#451
My Feedback: (20)
RE: AKM SU-27 Flanker-Does Look Good
ORIGINAL: bob27s
Thats actually a good idea on the control linkage.
Has been done before (RC kits T-38 if I recall correctly had a stab/servo setup like that).
Don
#452
YT, CANADA
Don after you open the Kit up .... do you want to send it my way? I mean you not going to have time to build it hahaha right?
#453
My Feedback: (20)
ORIGINAL: Blade47
You'll be getting kits, Pete...just be patient. I'll get around to it.....SOMEDAY! (LOLOLOLOL)
It's going to be Christmas in Canada later this year.
Don
#456
I used the Hitec HS-5475HB Digital for the ailerons. It is the first Digital servo I have used. It is a good servo.... however if I was going to do it again I would get either a HS-475HB(non-digital version of the same servo) or a HS-635HB. the 5475 is $35 the 475 is $18.
I will probably not buy digital servos again. The centering is great but the servo output is in didgits as the name suggests.... it tends to have a ratchety motion as opposed to a smooth motion... I can see and feel the difference.
I think the 475's and 635's are the way to go!
Rich
Rich
#459
Yes, I actually used the DB 60 mount.... not the 90 mount. The reason I used it is because there was a typo in the SU-27 instructions. The list of items needed in the begining indicates to use a 60 mount when it was intended to be a 90 mount! I had already mounted the engine and blind-nutted the mount by the time I realized the error.... but no harm done....both will work. I did have to widen out the 60 mount a little to get the Jett 90 to fit. The Jett 90 is a 60 sized engine!
here is a pic of the botton... not a great pic... I can take a better one if you need one!
Rich
Rich
#462
YT, CANADA
I used the DB90 mount and had no problems with it ...had to use the full length of the support arms ( almost ) to keep the right clearance for the spinner ...the width was OK.
#464
I used great planes CA hinges. They seem to be stronger than the rest.... have had flutter in many planes and have not seen one fail... yet!
Rich
Rich
#465
actually, I did find that the DB60 mount gave me a lot more overall clearance in the nose. I think the red, white and blue Flanker scheme is the best looking out of any I have seen!
Here is another paint scheme that is kinda cool!
Rich
Rich
#466
check out this link for pics of the real plane... scroll to the bottom!
http://forums.ubi.com/eve/ubb.x/a/tp...8491006042/p/7
rich
rich
#468
My Feedback: (8)
NC
Looking at the plans for the SU-27. I was wondering if changing the aluminium wing tube with a carbon fiber one would make that much of a difference?
Capt G. - I believe in over powering my models... But do you really think a Jett 90 is the answer for this one.
#469
My Feedback: (19)
OH
ORIGINAL: magnumeng
Keep in mind, the Jett .90L is a "60" size engine. Same size (and weight basically) as an OS61FX and OS91FX, and utilizes the same mounting pattern.
A 2.05 B .984 C 1.72 D 3.19 E 2.63 F 1.88
G 1.78 H 1.94 I 1.86 J 5/16-24 K 1.75 L 7.0
In any case, the Flanker is best powered by one of the small-block "90" engines currently available. Alex (designer) will be the first to tell you that. OS, ST, Jett, ASP, Magnum, TT, Evo 100 .... take your pick. Its a big plane. Needs some power in the nose.
There are a great number of larger prop-jets flying with the Jett 76 and 90L engines. I think Rich's plane is a good example of why the 90L is an excellent match-up in this particular design.
Bob
#471
Any engine will work... But you will get the most out of your plane with a JETT! The JETT will make your plane the BEST it can be! My wife just got me one of those new CERMARK F-16's for my birthday. I had seen the plane fly on a video post on RCU recently. It appeared to fly fantastic with a magnum .91.
The JETT will make it better.... BY FAR!!
Rich
Rich
#472
My Feedback: (8)
NC
The engine comment was about Capt G's little plastic model kit picture... I totally agree that a 90 or up is def needed for this bird. I will try to word my jokes better next time...
#473
My Feedback: (19)
OH
ORIGINAL: magnumeng
I think the Jett .35 will be enough for the small one [&:]
#474
YT, CANADA
Rich and Don
I have finished redoing the whole back end of the SU ... 1) redone the rudders with epoxy bearings, 4/40 rod across the fuse and 635 servo .. 2) reworked the control rods for the elevators ( no slop ), 635 servos on both elevators .... and to be on the safe side.... removed the extended elevator width that I had built in.
COME on weekend time for another test flight ...well after I have had a couple flight on the MIG just to get tuned up
#475
My Feedback: (20)
Test Flight? What's that? LOL. Looks good, can't wait to read the flight report.
See you in chat today if you get a chance, Pete. I finally get a whole weekend to work on the MiG's covering. I actually have th urge to monokote, can you imagine?
Later
Don
Later
Don
