If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 54 of 55 FirstFirst ... 44452535455 LastLast
Results 1,326 to 1,350 of 1357
  1. #1326
    Join Date
    Feb 2003
    Sandown NH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: AKM SU-27 Flanker-Does Look Good
    Hi
    Just received my short kit and it looks very nice. Trying to decide on the engine and retracts. I am looking foe an OS 91FX, Has anyone tried or used the new E-FLITE Electric retracts.
    Thanks in Advance
    Ron
  2. #1327
    Join Date
    Nov 2003
    Forest Grove, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Jaaron,
    That is correct. When sanded to size, it is a little thicker than 1/8" an tapers some to the tip.
    Very light and very strong. The kit is a joy to build.
    Mine is all glassed an ready for painting. Have not decided on the color scheme yet.
    Tony
  3. #1328
    Join Date
    Oct 2007
    Offutt AFB, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've got one wing built, and need to start on the other one. I've decided to put some energy into the fuselage and get it completed/sanded and ready for covering. I fuelproofed inside the engine area, and fuel tank area today. Tommorrow I'll hopefully finish sanding the fuselage and be ready for covering that area. I think i'm going to go with the red / while / dark blue theme. Seems easy enough to see in the sky when it's traveling at high speed.
    Thanks for the confirmation on the wing TE, just didn't seem correct to me, but Iknow I followed everything to the tee. At least I got and answer and can begin to move forward with this craft. It's been in the works for a couple years, then I got side tracked on a Top-Flite Stinson Relaint. Couple years later, now that the Stinson has flown, it's back to the jet and get ready for spring time fly'in.
    Jim
  4. #1329
    Join Date
    Nov 2003
    Forest Grove, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Jim,
    Mine has been in the ready for paint stage for two years.
    I moved, changed jobs and built a few kits since.
    Now I'm back on it.
    I added non functioning canards to mine to mimic the SU-33.
    The idea came from a post way back in this thread.
    I will try to get a few pics loaded sometime this week to show what I have done.
    Tony
  5. #1330
    Join Date
    Oct 2007
    Offutt AFB, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Last 15 Posts - reverse chronological order
    NoOneFlysAtMyClub
    Can you post a couple photos' of your wing tips?
  6. #1331
    Join Date
    Oct 2007
    Offutt AFB, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Got both wingsput on today, but still got to complete the underside of them. Also bought some servo's for the wings.Lot's of sanding left to do.Also glassed the nose area, as I suspect it will receive some abuse.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1681677   Click image for larger version.
  7. #1332
    Join Date
    Nov 2003
    Forest Grove, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Jim,
    Here are the wing tip pictures you wanted.
    The missile rails in the kit look too short and fat, so I made new ones.
    I am painting mine, so I fully sheeted the wing.
    The whole plane is glassed and sanded at this stage.
    I will post some pictures later of the whole plane.
    Tony
ID:	1681821   Click image for larger version.
ID:	1681822   Click image for larger version.
ID:	1681823   Click image for larger version.
  8. #1333
    Join Date
    Oct 2007
    Offutt AFB, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm thinking of leaving the Missle Rails off mine, and adding a little more to the wing tip. I know those will get caught on something heading out the to field, or while at the field, and that'll be it, so I'll just spair myself the upset now. Finishing off the wings today and getting the servos's placed. Probably will go ahead and sheet the entire wing for a little added strength. Anyone else have photo's of there progress or lack there of?
  9. #1334
    Join Date
    Oct 2007
    Offutt AFB, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Seems like I was inhaling sawdust all morning, but finally got 1 wing completed, sheeted the entire wing, and the ailerons, installed the servo, and servo horns, beveled the aileron and dry fit the hinges. 1 wing down and 1 to go, then all attention goes back to the fuselage and the rear tail feathers. Just out of curiousity what servo's are most using for the ailerons? I was thinking just going with basic servo's for the ailerons, and the heavy duty for the rudder's and elevators.
  10. #1335
    Join Date
    Oct 2007
    Offutt AFB, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Got the other wing completed today and sanded, and now all attention has shifted back to the fuselage. 1 area I had problems with was the wheel wheel areas. For some reason the tire mounts I bought for the retracts, were hitting the side of the engine nacelle. So I dug out the area so the retracts would function correctly, and mulled over what to do in this area.
    So today I decided to just cut and box the area instead of the deep gouge that was there. See below.
ID:	1682303   Click image for larger version.
ID:	1682304   Click image for larger version.
  11. #1336
    Join Date
    Sep 2011
    MσstolesMadrid, SPAIN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bueno,pues la guinda del pastel.......,,Al final me he complicado la vida un poquito y me he currado unas tapas de fibra de vidrio con resina epoxidica.
    Y aqui la tenemos....... ,lista para cortar a medida,pintar y poner
    Colocado todo el tema de receptor,pila,interruptor,comprobador de pila....etc...
    Se acabó,ahora a esperar que venga un día bueno para poder estrenarlo.Lo próximo ya el estreno.
    Saludos
  12. #1337
    Join Date
    Oct 2007
    Offutt AFB, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just got back from the hobby store and bought some covering along with a trim seal tool, for ironing the small areas.  Thinking I'll start covering the wings tonite so I feel I'm making some progress.
  13. #1338
    Join Date
    Nov 2004
    Clarkston, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bueno, me gusta mucho.
    Good times.
  14. #1339
    Join Date
    Nov 2003
    Forest Grove, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here are some shots of my progress.
    Fixing small imperfections.
    Should be shooting primer in a few days.
    The canard is fixed. Set at '0' with the stab and wing.
    Power is a Super Tigre S.90K with tuned pipe.
    Tony
ID:	1683582   Click image for larger version.
ID:	1683583   Click image for larger version.
ID:	1683584   Click image for larger version.
ID:	1683585   Click image for larger version.
  15. #1340
    Quikturn's Avatar
    Join Date
    Jan 2008
    West Des Moines, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Great job Tony,
    I like those canards. Someone earlier in this thread talked about getting those to articulate. I thought a carbon fiber rod which carries through the fuselage could be used to connect both of them together. Then glue a control horn onto the rod inside the fuse. The question then is how to mix it in to the controls. It would be nice to have those canards assist in lifting the nose during slow speed flight (keep the nose up during landing) but I don't think it would be good to have them move during high speed flight.
    Has anyone beefed up or made any mods to the elevator?
    No matter how many times I cut it, it's still too short!
    Ultrasport Brotherhood #45, P-51 Brotherhood #34, P-40 Brotherhood #35, Saito Club member #799, Spitfire Brotherhood #173, Glow head #18
  16. #1341
    Join Date
    Oct 2007
    Offutt AFB, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Okay so no covering has been completed yet, due to other projects that have come about. However after seeing those photo's with the Canard attached, you've got me thinking about them again myself. While I wouldn't want to make them functional, they are very cool.............wheels are turning.
  17. #1342
    Join Date
    Apr 2005
    CardwellQueensland, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Can anyone tell me if you balance this plane with retracts positioned up or down
  18. #1343
    Join Date
    Nov 2003
    Forest Grove, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    UP!!!!
  19. #1344
    Join Date
    Apr 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Mate, as this is my first retract venture I was sure it was up but needed some asssurance.Just hope it flys as cool as it looks.
  20. #1345
    Join Date
    Sep 2004
    Omaha, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Squizzy!
    Hope you are still working on your bird!
    I flew my SU-27 today. Was having problems with my Jett Engineering motor and final leaned out the low end and that did the trick! I was screaming down the runway and fell in love with this machine all over again! I didn't even put it in storage...going to keep flying it like I used to!
    Keep up the good build!
    Joe
    Autogyro Crazy
  21. #1346
    combatpigg's Avatar
    Join Date
    Nov 2003
    arlington, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    How fast do these "Extreme Speed Prop" planes fly..?
    They look like a lot of work for a modest return in actual speed.
    Would a sport plane like a Chaos or Ultrasport be as fast or faster with less power..?
    That's not an Indian movie man, that's a test pattern....
  22. #1347
    Join Date
    Nov 2003
    Forest Grove, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yup!
  23. #1348
    Join Date
    Sep 2004
    Omaha, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Probably...but it won't look as good going this fast!
    Autogyro Crazy
  24. #1349
    SpeedBoy's Avatar
    Join Date
    Nov 2007
    Monterrey, MEXICO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: NoOneFlysAtMyClub
    Tony
    Tony , do you have more progress on your Su-27 ???
    Would be great to see it with color .
    Living on a War Zone !!!!!
    Seriously
  25. #1350
    Join Date
    Nov 2003
    Forest Grove, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Speedboy,
    My wife and i have spent the last six months building a new house. No hobby time.
    Just now starting to get my hobby space set up.
    The plane is in primer, final sand stage (before the move). I have three small dings to fix (so far).
    I will probably start painting after the first of the year. When I do, I will post some pictures.
    Tony
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
