AKM SU-27 Flanker-Does Look Good
Reply
Old 01-14-2005, 12:00 AM
  #126
Cyclic Hardover
Cyclic Hardover's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: AKM SU-27 Flanker-Does Look Good
Well, Congratulations! Since you know your final weight, you have been duely designated to put that thing in the air and report back to us. According to everybody involved here, your in the lead. What engine do you have up front.? Got any picture for us?
Quote:
ORIGINAL: THEGRINCMAN
I had my SU-27 built by a local club, I balanced it at what the plans call for , and it took a harry higley heavy hub to balance it out. I got to say , I wonder if it will be tipsy side to side. It dont feel solid on its feet. The weight come in at 8 1/4 lbs. I hope to see some test flights before I try mine.
Cyclic Hardover is offline
Old 01-14-2005, 09:13 AM
  #127
bob27s
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hopefully after I get my daughter's bedroom painted this week, I can start building mine!!
Its pretty sad when the kit collection not only collects dust, but starts mummifying !
bob27s is offline
Old 01-14-2005, 09:07 PM
  #128
jetpilotrich
jetpilotrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey guys! I have been following some of the discussions on the AKM SU-27. I have finished mine and it is days from being flight ready. The CG has some issues. I would like to send a couple of pictures for everyone to check out and comment on. I have found some differences in the completed model and the plans.
Rich
jetpilotrich is offline
Old 01-14-2005, 09:21 PM
  #129
Blade47
Blade47's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have added some more pictures of my Finished MIG29 on the balancer ( done today )... a good read about the C/G and the weight .
http://www.rcuniverse.com/forum/m_21..._4/key_/tm.htm
Pete
Blade47 is offline
Old 01-14-2005, 09:22 PM
  #130
Joe Ortiz
Joe Ortiz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rich, post your pictures and build findings here, I have been following this thread myself, 'cause I was thinking about building this plane, seems everybody has the same CG concerns, maybe I'll wait until you guys fly yours and I'll get mine
Joe
Joe Ortiz is offline
Old 01-14-2005, 10:57 PM
  #131
Cyclic Hardover
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ohhhhhh boy! I have seen all this coming but not going to deal with it until its time. Those fins under the back end may take a beating. Have not decided on that deal yet. That whole back end is going to be very very close to the ground on landing. I have this composite stuff that is a very hard plastic looking sheet and I cut in tiny pieces and use them for skids on my shrike or wing tip protectors. I am going to try and mount them where they won't show much to protect the back end
Quote:
ORIGINAL: jetpilotrich
Rich
Old 01-15-2005, 01:39 AM
  #132
jetpilotrich
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is the first pic. Note that the CG is ahead of the Main gear on the plan but the gear is actually farther foward then it is in the plan which puts the CG behind the main gear. the plane sits ok on all 3 gear but this obviously puts the CG farther foward then it is on the plan! The gear mounting is foolproof..... the laser cut gear plate fits exactly between the F5 and F6 formers.... even the holes are laser cut for the retract screws. let me know if anyone has noticed this. Also note that the retracts are not to scale on the plan.... they are huge when compared to the actual retract unit.
I tried to upload the picture....if it does not show up I will try it again later.
Rich
ID:	215369   Click image for larger version
Old 01-15-2005, 11:13 AM
  #133
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK... Question:
I want to order my retracts... what exactly do I have to order?
I'm thinking: #101HD three gear system 3/16" struts, #117 hand pump with gauge, #132 hand pump coiled tubing, #143 right hand main strut 3/16", #144 left hand main strut 3/16".
Is that all I need, or are there things I am missing here?
The Spring Air pages aren't exactly well documented...
Rudeboy is offline
Old 01-15-2005, 11:20 AM
  #134
jetpilotrich
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used the 101HD which have a 3/16 wire, the 5-32 (regular 101) wires would just woble all over the place especially the nose gear.
Rich
Old 01-15-2005, 11:44 AM
  #135
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, but are the wires included with the retracts, or do you have to order them seperately?
Rudeboy is offline
Old 01-15-2005, 12:07 PM
  #136
AirGar
AirGar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
RudeBoy,
I have a set of Spring Air 302 HDR NIP I bought for my Starfire DF jet that's sitting here collecting dust. They look like 3/16", with air line and tank. Not sure if the exchange rate would allow us to do business or if they'd be a little heavy for the Flanker?
Gary
AirGar is offline
Old 01-15-2005, 04:20 PM
  #137
jetpilotrich
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The 101HD set should come standard with the 3/16 wires. That is how mine came. I think the regular 101 set is the 5/32 wire version and the 101HD is the 3/16 version. The "HD" is the thicker wire.
Rich
Old 01-16-2005, 03:11 PM
  #138
Blade47
Blade47's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Snoop I have a "Q" for you ... with the spring air 101HD retracts ...will the package come with mounting bolts? If not what did you use to mount them?
Pete
Blade47 is offline
Old 01-16-2005, 08:17 PM
  #139
Cyclic Hardover
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, I forgot what size I used but I have blind nuts on the back side. You also may have to grind down one corner of the main unit. That is another quirk I found. Take a good look at the plans on the flat display where it says" F-5 and right their is also a schematic of the retract. Look close and you'll see one corner which looks like its crossing over a line? Well , that corner of the retract is actually inside the fuselage. Apparently AKM mounted the retracts and built the side of the engine tubes over it.
This leads me to ask myself, "how do I remove the retract without ripping off part ot the wall? This is dumb so I ground off the corner to make it fit. Also if you are planning on glassing, Dont bother installing the blind nuts cuz you'll get slop all inside.
I found it------6-32's
Old 01-16-2005, 08:26 PM
  #140
Blade47
Blade47's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cool thanks Snoop
Pete
Blade47 is offline
Old 01-16-2005, 08:37 PM
  #141
Cyclic Hardover
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
get extra blind nuts, they tend to stick , or the bolts get stuck and twist around and stupid things. Using WD 40 helps when putting the bolts in
Old 01-16-2005, 09:54 PM
  #142
jetpilotrich
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey guys!
No need to file down your expensive retract unit. Alex at AKM did a nice job designing it so you cut into the wood and insert the corner of the retract unit. I sent one of his pictures. It was intended that you notch out the wood, put the retract unit down on the retract gear plate and twist the unit under the wood and then screw it in place.
Hope this helps!
Rich
Old 01-16-2005, 10:49 PM
  #143
Cyclic Hardover
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good picture, I could not twist mine in so I "fixed it"
Old 01-18-2005, 08:55 PM
  #144
picard1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I started my wings over the weekend since my spring air 701 haven't arrived and I started looking into what modifcations are required to the fuse for 3/8 oleos. Also, after reading the discussions concerning the retract position relitave to the cg, I did some research on the position of the rear retracts. They appear to be further back behind CG, and swing forward in the retracted position. Take a look at the savage su-27.
So, my idea is to find the balance point on a completed retract with oleo's and tire, place that point on or forward of the CG. When retracts swing forward and lock the plane would balance when deployed this would shift CG to the rear creating a slightly nose heavy situation for landings.
Ok guys I am no engineer! so give me some feedback!!!
Picard
picard1 is offline
Old 01-19-2005, 08:49 AM
  #145
bob27s
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Alex has had the design out and the plane flying for a few years now. The design has prooven out fairly well. Keep with the CG as on the plans, and you will be ok.
On an aircraft with this sort of fuselage surface area, more than just the wing comes into play when determining the cg. Keep that in mind.
The CG change from retracting the gear is negligable. There is also an aerodynamic pitching moment change that goes along with retracting/extending the gear. From looking at the geometry, id imagine they balance out for the most part.
On this type of plane, the last thing you really want is an overly-noseheavy condition for landing. You will run out of elevator in a hurry.
bob27s is offline
Old 01-20-2005, 03:01 PM
  #146
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Snoop,
Do you happen to have any idea how much weight the glass job added to the bare airframe weight?
I'm already wondering how I'm going to finish this thing... Mine seems to have a lot of hard (read heavy) balsa in it, and I don't want to make it an overweight brick. Looking at the pile of wood that still has to go into this thing, I can't help but wonder about the finished weight.
A film job would obviously be the lightest route... but this thing looks like a real bear to film finish...
PS: Check this one out! [link=http://www.umfc-kirchschlag.at/sites/su27projekt.htm]Harald Kafka's SU-27 Flanker[/link]
Rudeboy is offline
Old 01-20-2005, 05:00 PM
  #147
Cyclic Hardover
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well right now I am at about 5lbs after my glassing but no paint yet. What is on the plane other than the glass job was the retracts and a couple servos. So I think I am in good shape at the moment. If I can bring this in at around 8 1/2lbs, I'll be happy. That is what my red Ultra Sport 60 with my other Jett 90 weighs in at.
The guy who I have been talking with on this Minwax thing was the guy who had this Big Dauntless that won some best in show thing somewhere. He said that the overall weight increase using this method was far less than the traditional epoxy resin, plus it drys reall fast. Were talking a couple hours here. I can get several coats on in one day.
I only glassed the fuselage, I am covering the wings. Thats a piece of cake.
Old 01-20-2005, 05:04 PM
  #148
Cyclic Hardover
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How about a picture of the whole thing?
Rich
Old 01-20-2005, 05:31 PM
  #149
jetpilotrich
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Will get some out shortly. I just got a new camera and I want to get some great pictures for Alex and everyone. I just need to break in the engine and fly it. If weather permits and no other problems are found during the engine break-in/taxi tests.... I will probably fly it this weekend! But you know how that goes..... usually something needs to be tweaked or adjusted.
Hopefully I will have some pics by the end of the weekend......
Rich
Old 01-20-2005, 10:23 PM
  #150
Cyclic Hardover
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You recall what your weighing in at?
Rich
Reply
Display Modes
