Prop question?
Reply
Old 09-20-2004, 10:00 PM
Zeroman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Prop question?
Can a prop fly faster than its calulated speed?
Zeroman is offline
Old 09-21-2004, 04:21 AM
der_steuermann
der_steuermann's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Prop question?
No, even if considering an ideal environment (no draggy airframe/engine, no air resistance) the theoretically calculated speed would be the best possible one.
From experience a very good speed setup reaches about 90% of the theoretical prop speed at given rpm (rpms of an unloaded engine during a powerdive derived from Doppler effect measurements).
Boundary conditions are:
- low drag airframe supporting the engine/prop combo to unload with ease after the first dive
- low drag speed prop designed for a certain rpm and target speed
- an engine swinging the prop within its highest efficiency
- preferably subsonic prop tip speeds
- speed measurements in both directions, headwind and downwind
der_steuermann is offline
Old 09-21-2004, 09:25 AM
Zeroman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the info der-steurmann, there has been quite a discussion about this.Some club members say they fly faster than the calculated speed all the time.Chris.
Zeroman is offline
Old 09-21-2004, 10:19 AM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm not convinced that a prop CAN'T fly faster than its calculated speed.
I think its possible, but it may be due to incorrrect pitched props.
I've seen APC 10x7 props go faster than what they should be capable of going.
daven is offline
Old 09-21-2004, 11:59 AM
Mike Connor
Mike Connor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Since a typical prop starts developing forward thrust at a negative 3* pitch I would have to say yes. The calculated forward speed of a 0* pitch prop would be 0 but under the right circumstances it may even get a plane off the ground. This advantage is usually lost to drag as speed increases.
Mike Connor is offline
