My DD after 8 hrs.
Reply
Old 08-05-2002, 11:09 PM
soarrich
My Feedback: (98)
soarrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default My DD after 8 hrs.
My hats off to anyone that can build this thing in 2 1/2 hr., I've spent that long just look'n at the plans.
My Picco has a rear carb which complicates the mounting. What I found easiest to do was put 1/2" of AC ply under the mounting lugs. The engine JUST goes below the mounting plate by maybe 1/8". I may fill the bottom of the mount in with balsa so it won't catch on landings.
I only have a 8 oz. tank on hand, it seems to fit OK, so I'll use it. Where do you pickup pressure from a pipe, by the engine , or at the fat part of the pipe?
soarrich is offline
Old 08-05-2002, 11:11 PM
soarrich
My Feedback: (98)
soarrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Another picture.
soarrich is offline
Old 08-05-2002, 11:13 PM
soarrich
My Feedback: (98)
soarrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry I goofed.
soarrich is offline
Old 08-06-2002, 12:00 AM
ChuckAuger
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Pipe tap..
Put your pipe tap about 1/4" in front of the fattest part of the pipe. And I can't really see, but you're not raising your thrust line 1/2" are you??
ChuckAuger is offline
Old 08-06-2002, 01:20 AM
soarrich
My Feedback: (98)
soarrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Re: Pipe tap..
Yes, I know that will pull the nose down somewhat. Do you that that it will be unacceptable?
soarrich is offline
Old 08-06-2002, 01:22 AM
soarrich
My Feedback: (98)
soarrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mount picture.
soarrich is offline
Old 08-06-2002, 01:33 AM
soarrich
My Feedback: (98)
soarrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mount
soarrich is offline
Old 08-06-2002, 01:37 AM
ChuckAuger
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Yeah...
I would mount the engine on the ply plate, put the beams under the ply plate extending back past the firewall, and cut the firewall out to make room for the carb. It looks like you have to butcher the firewall pretty bad, but I've had abot 4 less than perfect launches and mine is holding together..
Old 08-06-2002, 01:43 AM
soarrich
My Feedback: (98)
soarrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK, better now than after it's all covered.
soarrich is offline
