Radio Setup for Delta Wing ??????
Reply
Old 10-06-2004, 12:42 PM
DragonHeart
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Radio Setup for Delta Wing ??????
Hi Guys,
Just a query, ive nearly finished my TigerShark and was wondering if anyone can give me any help with how to set the radio up ??????
I have a Futaba 9C but never used an advanced setup before and kinda lost the instruction manual [X(]
On the TigerShark Instructions is states Elevator up and down 15mm and Ailerons up and down 10mm, but im sure i read somewhere with an Elevon Mix you should set up one aileron movement different to avoid corkscrewing in turns ??????????
Any help would be extremely Helpful Thx in advance
DragonHeart is offline
Old 10-06-2004, 02:48 PM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Radio Setup for Delta Wing ??????
You can probably download the mnual from the Futaba website.... I use the 9C with a Whiplash (Delta) as I recall I just use the elevon mix, nothing fancy---
Razor-RCU is offline
Old 10-07-2004, 03:11 PM
Crazy4Flight
My Feedback: (540)
Crazy4Flight's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you will need to have the full 15 mm travel for the elevator upon landing
set radio wing type delta - elevons
aileron channel is left wing
elevator channel right wing
use the dual rates to set yout throws
Crazy4Flight is offline
