Shoestring vs Lil' Toni vs Rare Bear
My Feedback: (56)
AL
RE: Shoestring vs Lil' Toni vs Rare Bear
I'll throw my Shoestring up against any of the other two with similar engines. I would imagine that the powerplant/prop combo is going to dictate the winner. I clocked 112mph at 250msl in a dead level run. Not bad for a 7lb airplane all up. OS61FX swinging 12x8MA.
I agree that the hottest engine/prop would rule, so ya gotta have some limits
What about up to a 91 sport 2-stroke for one class (stock, unmodified)
And a second class--unlimited (any mods allowed, 91 2-stroke, 120 4-stroke)
Sound Interesting?
WW
Sound Interesting?
WW
My Feedback: (27)
I'm planning on "stuffing" my Y.S. 120 in the 'lil tony. I think it'll move pertty good. I'm gonna have to beef up some of the weaker spots though.
Neo
Neo
I'm going to build a Lil' Toni for my OS 120 III pump... I tached it with a 14 x 14 APC at 10,800 rpms. On my Thrust calculator that would be 143 mph!!! I can't wait....
Check out this link for a complete set of rules for Formula One / Goodyear racers
Both the Shoestring adn the Toni are legal.
http://www.pylonworld.com/rc_pylon/f...port_rules.htm
Full size, the Rare Bear would eat up the Little Toni and Shoestring!!
Is there much full size Formula 1 anymore? Probably been hitting all the wrong web sites - there's an awful lot about Unlimiteds out there.
<<Full size, the Rare Bear would eat up the Little Toni and Shoestring!! >>
Let's see, 3000+ hp VS. 135 hp. However, if I set up the race course, I could rig it where the Bear wouldn't stand a chance. The full size F1's race on a three mile course, while the unlimited are on a 19 mile course. Nothing prepares you for the sound of the unlimited planes going by at 500 MPH. However seeing a F1 go by at 250 on such a small engine is pretty impressive too.
My Feedback: (28)
MO
I just finished installing a YS 110 on my shoestring. It ran good with the Satio but it was junk and craped out... No its got a New YS...
My little tony has a Jett F.I.R.E. on it.. Should run fast. Swing a 9x9 20,000 unloaded.
CA
I recently finished a Lil Tony with a YS 110. I'm running the YS header and a 12 x 10 prop and Powermaster 20/20. I radared at 144 mph level flight. Great flying plane and hot on landing. I've also got a Shoestring with a Rossi 60. Radared at 118. Fun to fly but no comp to the Tony. 468hotrod - that engine is wrong for the Tony. I've got that on a Cermark Pitts where its perfect for a work horse. Its not a race engine. Its too large for the cowling and too heavy for the plane.
Hey Harvey,
I ran your numbers on my thrust calculator and your YS110 would have to turn 15,200 rpm's with a 12 x 10 prop to run 144 mph. I have a YS110 and it will not turn 15,000 rpm's with ANY prop. That motor is only good for 12,000 max... I agree the OS120 is heavy. Probably 4-5 ounces heavier than the YS110. But I am not trying to turn high rpm's just need the torque to turn the higher pitch props. My bud has a pitch meter and we are going to re-pitch a 13 inch prop to a 13 x 16 to try it. This setup just needs a lot of brute strength to hit 10,000 rpm's... Just a different approach to speed than the high rpm 2-strokes... We'll see how it goes... I am using my YS110 in a Funtana 90 right now.
Ray
Ray
CA
Ray -- Let me know how your prop gig works. I know I'm revving the motor to death and really don't expect it to live to long anyway. Harvey
ORIGINAL: fastford
I'm just about to fit a soon-to-arrive Jett .90L (side exhaust) to mine but I'm keen to see a good FIRE installation all the same. I have a new circa 1980 OS VF .61 FIRE sitting in a drawer as an alternative powerplant.
Thanks in advance
My Feedback: (19)
OH
When anyone gets a side exhaust install in a Toni done..... I'd like to see some pictures too!
I sorta have a layout for the rear exhaust. Going to help out a friend with that this weekend hopefully. We shall see how that works
Bob, keep us posted.
Are you thinking of taking the header right through the fuse portion of the cowling "side pod"?
Although the .90L hasn't yet arrived, by the dimensions on the Jett Engineering site, that Jett Stream muffler looks like it's going to go a long way into the bottom right of the fuselage.
Dub mentioned that you guys may have angled spacers to help kick out the end of the muffler up to three times the standard angle. This may help.
I'll update you guys when I get the engine in the next couple of days.
BCherry, I'd start with a 12x12, which your engine should pull in the mid to high nines. A 13x10 won't be as fast, but will be a good compromise between outright speed and vertical performance.
I'm running a 13x10 on a Cloud Dancer 60 with an OS91 Surpass doing about 9200 static. The 12x12 does about 9500.
Hey Cyclic-
Didn't think of them, but I guess we should add the World Models Midget Mustang to the mix
Now all we need to do is get a group of guys that have all of the above and want bragging rights to the fastest one...
WW
WW
ive got a shoestring with a supertigre 1.40 2 stroke. 11500 static rpm with 14x14 prop. could somebody please work some thrust calculator magic and gimme a ballpark figure on speed? thanks. like the looks of the lil tony..
Erik
Erik
That would be 152.47 mph... What is the weight on the ST 1.40?? I am planning on using a OS FS120 Surpass II on the Lil' Toni... I was wondering what the weight difference would be. The OS 120 turned 10800 with that same prop... It should run 143 mph. Since you wouldn't need the extra thrust with these small planes I was going to pitch my own 13" prop up to about 16 pitch to reach about 150-155mph...
Ray
Ray
thanks hotrod.. the book says 37.65 oz with muffler (1073gr). i used an inverted bisson pitts that i think is a little lighter than the stock muffler. ive got like 15 or so flights with this setup so far and she gets along nicely . i like the more pitch idea too.
thanks
Erik
thanks
Erik
Tomorrow I'm maidening my Little Toni with a Saito 1.00 on 30% nitro and an APC 13x10. I have a 12x12 on order as I hear it is a bit faster.
Hey Bob just ordered a jett 90l for the lil toni Dub has the propper spacers for the exaust figured out now mine will fly next weekend the plane is built and waiting for the insane powerplant to show up cant waite!!
ORIGINAL: bob27s
