Please, I need Speed!!!!!!
Reply
Old 10-11-2004, 08:12 PM
freebird1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Please, I need Speed!!!!!!
OK, I have, or have had several planes. For example, javelin, Patriot, Phantom, Giles, Cap, Spectrum, and the list goes on. I put the best engines( Rossi Jett Mvvs) for weight and power and prop(APC Scimitar) on them. All I can seem to get is about 100-120 MPH. I have not owned a belly lander yet. I love the way the Patriot, Javelin, and the Spectrum fly and land. What is a Plane that is FAST and $, but can fly great. I have been looking at the Magnum, but can not find where I can get one(back ordered). I love speed!
Please Help?
Freebird1
freebird1 is offline
Old 10-11-2004, 09:14 PM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Please, I need Speed!!!!!!
Put a Jett .50 on a Viper or Predator and you will break 150 mph.
Best of luck.
daven is offline
Old 10-12-2004, 08:04 AM
freebird1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
where is the best place to buy a Viper or Predator?
Old 10-12-2004, 09:59 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you can order either from your local hobby shop, and they are also commonly available from Tower.
Both are Q-500 aircraft...... ARF construction. Good airplanes.
As Dave noted, Jett .50..... and 150 is in your grasp. And guess what..... you get to have wheels too
if you want to go for the top speed, get the SS muffler combined with the Jett 50. Tuned for higher rpm... perfect with the pylon D-1 series APC props. Runs like a 428 pylon engine on steroids.
If you want something more along the lines of a Magnum, look up [link=http://www.rcuniverse.com/forum/showprofile.asp?memID=92292]Angel [/link] on here (past threads). He has a few aircraft that will most definately suit your speed needs.
Bob
bob27s is offline
Old 10-12-2004, 10:06 AM
SSAN
SSAN's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: freebird1
What is a Plane that is FAST and $, but can fly great. I love speed!
Please Help?
Freebird1
Depending on how fast you want to go or how much you want to spend, here's the info to get these planes.
For Quickie 500 planes, http://www.pylonworld.com/rc_pylon/q...500_planes.htm
For Quarter 40 Planes, http://www.pylonworld.com/rc_pylon/q...-40_planes.htm
Hope this help!
SSAN is offline
Old 10-12-2004, 01:23 PM
AirGar
My Feedback: (7)
AirGar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's the "Rifle", made by Angel.
I'm hoping for 160-170 mph when she's done.
Gary
ID:	182028   Click image for larger version
ID:	182029   Click image for larger version
AirGar is offline
Old 10-12-2004, 07:18 PM
freebird1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Has anyone flown a sonic 500. I like the looks of it. I was thinking of a Rossi 53 with long pipe and APC 9x8 prop. What do you think. I am looking for something in the 150- 175 MPH range.
Thanks you are a big help
Freebird
Old 10-12-2004, 07:37 PM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have flown the Sonic, the older ARC version, not the newer ARF version. They are the same basic plane, just different levels of completion. With a Rossi .53 I don't think you will see 150-175 mph.
I would estimate it closer to the 130-140 mph range.
Great flying plane.
daven is offline
Old 10-12-2004, 07:53 PM
freebird1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The other plane I am looking at is the viper. I just downloaded a short clip and it seems to fly great. Is it any faster than the sonic and how does it preforme. Can I use the rossi, it alittle heavy?
Old 10-13-2004, 08:45 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Freebird......
Any of the Q-500 aircraft will get you very good speed, and all of them fly well and are well behaved.
For ARF's, the Viper and Predator are a bit faster (and better constructed) than the Sonic 500. The Sonic is basically an ARF version of a Scat Cat, and that design has been around since the early 1980s.
Hanging a full-size tuned pipe on a Q-500 aircraft tends to do more harm than good.......too much drag. Usually not worth the trade-off.
As Dave noted, do not expect to see much over 140 with a Sonic and the Rossi. With the right prop, you can probably push a Predator up near 145 with the engine. I'd imagine the GP Viper would be close to that.
In a non-racing environment, and with a top end tuned and properly propped engine, you can push a well built Q-500 airframe over 175 mph in level flight. This takes a great deal of care, setup and good construction.
I am not sure if a Rossi 53 can take any Q-500 airframe up in that range. It might.
I know the Jett SJ-50 SS setup can exceed 428 racing performance.
Bob
bob27s is offline
Old 10-13-2004, 05:34 PM
freebird1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK
I think I am going with the viper for speed and performance. A problem I have already seen is it comes with only a 6 OZ. fuel tank. The Rossi loves fuel and would only make a 3 1/2 min flight. Has anyone istalled a biger fuel tank, and was it a big deal.
Thanks!!!
freebird
Old 10-14-2004, 05:41 AM
Peter Pankras
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You could take a look at www.speedmodels.nl if you're not afraid of speed..
Peter
Peter Pankras is offline
Old 10-14-2004, 08:42 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you will be hard pressed to install anything more than 6oz tanks in Q-500 aircraft.
best bet is to install a bubble free tank from either Tetra or Jett. This way you can use all 6 oz without the engine going lean. But that is not an absolute necessity.
bob27s is offline
Old 10-14-2004, 08:28 PM
freebird1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HE HE
To the air, To the ground all my birds are WFO. Araid not, crave Yes.
Thanks for the post
I was looking for a 40 size for a side exhaust
freebird
Old 10-15-2004, 02:41 AM
Peter Pankras
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
size 40.. - the stinger 40 is as the name says for .40 and up engines.. there is a side, and rear exhaust version.
Cheers
Peter
Old 10-15-2004, 04:17 PM
freebird1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I did see the Stinger .40 with side exhaust. It is a super fast and slick looking plane, but there is very little info on the site. No pricing, examples of the stinger side exhaust, or online ordering. I did fill out the order form & pressed send. I really do not know what it did because nothing ever happened.I may have missed something.
freebird
Old 10-15-2004, 04:46 PM
Peter Pankras
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Freebird..
When did you fill out the form?
The site is currently being updated since I took over production.. there could be a gap somewhere.
I currently working on the backlog and getting orders done for dealers first.
I will be taking orders soon.. keep an eye on the site.. and if there is anything you want to know you van always contact me at speedmodels@planet.nl
Cheers
Peter
Old 10-16-2004, 10:35 PM
freebird1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think it was the 14 th. There is no doupt the stinger is a super fast and slick plane, but I would like a little more info.
Old 10-17-2004, 02:18 AM
Vmax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
@freebird
go to the info page. hobby barn sells it. Price at the stinger page-> 150 Euros.
or[link]http://www.speedmodels.nl/Speed%20Models/Stinger/paginastinger.htm[/link]
Vmax is offline
Old 10-17-2004, 09:40 AM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On the info page it says you need a 45mm/ 1.75" spinner... My Stinger needed a 2" spinner. So I got a 2" counterbalanced spinner from Jett when I ordered my engine... good thing I ordered the plane first, and the engine next, or I would have been stuck with a spinner I have no use for. Since the Jett spinners are intergrated into the engine, the spinner backplate mounts directly on the crankshaft and replaces the prop driver.
It has a semi symmetrical airfoil.
The tail feathers are a balsa-plywood-balsa lamination, with cutouts already in place in the plywood for the hinges.
The only difference between the side and the rear exhaust model is the "cockpit" (glass part that is glued in top of the wing). The rear exhaust cockpit has an indent to receive a tuned pipe.
What more do you want to know?
Rudeboy is offline
Old 10-17-2004, 04:00 PM
bigchap
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i've just seen a ripmax rapier fly with a webra speed.91 up front,i don't think i've seen a quicker plane[magnums included].
bigchap is offline
Old 10-19-2004, 07:35 AM
Evil Homer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I cant see the Rapier lasting that long with a 91 on it
Evil Homer is offline
