anyone know the Robbe Rasant ?
Reply
Old 10-16-2004, 06:32 AM
vulpina
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default anyone know the Robbe Rasant ?
Hey all , i just found a cool speed plane i could use with my mvvs quickie 40:
[link]http://www.rchobby.co.uk/robbe_rasant_speed_arf.html[/link]
Anyone got experience with this one ?
It is a 40 plane and it comes ARF !
vulpina is offline
Old 10-16-2004, 07:51 AM
der_steuermann
der_steuermann's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: anyone know the Robbe Rasant ?
The ROBBE Rasant has been released sometimes 20 years ago in kit form - it is kind of classic speed construction widely used in Europe. After disappearing for a long time Robbe again reactivated that speed plane - this time as an ARF. It’s a perfect speed trainer.
Here's a picture of the Rasant powered by the Nelson 40 Q-40 engine. It is hardly controllable with that much power - or in other words, the airframe seems to be aerodynamically overstrained (aileron flutter above 180 mph). Mounting heavy duty hinges and sealing the hinge gaps of all control surfaces should solve these problems...
However, using the MVVS Quickie engine on the Rasant would be a good solution – and one of the cheapest too. With the APC 7.2*8.6 racing prop and the tuned silencer # 3246 you can expect about 150 mph right out of the box.
der_steuermann is offline
Old 10-16-2004, 10:27 AM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's a nice looking plane! The short nose / long tail leads me to believe that the designer has a heavy engine in mind, but there isn't much wing area. This looks like the type of plane that you land where ever it's short glide path wants to take you. 970 mm span is probably about 3 ft, which is what I use for .15 sport designs! I would like to see someone build it and give us a flight report.
combatpigg is offline
Old 10-16-2004, 01:21 PM
vulpina
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i just got home with the kit , its 160€
I will put my mvvs quickie on it , i would like to use it as rear exhaust but it need alot of mods :/
The overall plane is built pretty light and the wing is one piece and look solid , there is a f/g cowl also
Btw do you have any ideas how to mount the quickie with RE iam using the 3246 ntuned silencer ?
vulpina is offline
Old 10-16-2004, 09:25 PM
Nik
My Feedback: (12)
Nik's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just came back from a germany and read a review in a german magazine.
The author said it's very quick, agile, and alot of fun. Only negative thing he said was that the arf was abit heavier than the kit's they used to produce some years ago..
Nik is offline
Old 10-17-2004, 01:37 PM
vulpina
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yea its a nice plane overall , but i got some trouble deciding how i will fit my mvvs quickie engine , i want to use it as rear exhaust but i dunno how .
I cant put the silencer over the wing because i need to take the wing out often., i cant put the exhaust under the plane because there is no wheels
Even to use side exhaust i have to tilt the engin a bot to get a good clearance between pipe and wing .
Dam this is giving me headache
Any tips ?
PS: Do you thing HS80mg is enough of a servo for ailerons and elevator or should i use something stronger ?
vulpina is offline
Old 10-19-2004, 04:31 AM
der_steuermann
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'd mount the rear exhaust engine upright. The (custom) exhaust clamp should be placed within the first half of the tuned muffler. That allows the wing to be removed freely.
The servos of elevator and ailerons should provide at least 40 N of torque. Ball bearings are recommended, metal gear is not required.
Old 10-19-2004, 07:08 PM
vulpina
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I went side exhaust , its was easier to mount .
Btw i dont have the same muffler as in your picture , mine came with the long header its #3246 "quickie" side exhaust , hope it works ok .
vulpina is offline
Old 04-06-2007, 05:59 AM
KrisG
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There is one of these, original kit, not ARF on Eb*y Germany right now. I suppose it is going to be quite expensive eventually, as this plane is still very popular in Germany. This one is the straight wing version, btw, not the Rasant Speed.
http://cgi.ebay.de/Robbe-Rasant-Flug...QQcmdZViewItem
Kris
KrisG is offline
