Wing tips on a quicky 500...
Reply
Old 10-21-2004, 08:38 PM
MOJO65-9or10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Wing tips on a quicky 500...
Hey all I have a running post on my Zoomer build with a 15% wing and I now need to finish the wing by coming up with some SLEEK wing tips. I would love some suggestion's.
The wing is flat with a full sym 15% wing.
Thanks Dave
ID:	185169   Click image for larger version
MOJO65-9or10 is offline
Old 10-22-2004, 12:20 AM
Flyboy Dave
My Feedback: (21)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Wing tips on a quicky 500...
Where are the wing-tips that should have come with the Kit ??? [sm=surprised.gif]
FBD.
Flyboy Dave is offline
Old 10-22-2004, 12:57 AM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Foam
Razor-RCU is offline
Old 10-22-2004, 08:42 AM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree, foam would be easiest. Just glue a block on, and sand to shape. Or, you could do the same with balsa, but if you don't hollow it out, it could be heavy. Last option would be to glue on what is known as razor tips. Basically 3/16" thich balsa about 1-1 1/2" wide to the end of wing. Put a couple pieces of try stock top and bottom, and then cover over the tip.
daven is offline
Old 10-22-2004, 09:59 AM
MOJO65-9or10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The kit I am building just came with wing cores, a fiberglass fus, and plans. The planes show the tips need to be rounded but I haven't made wing tips before. I think this is done because people who build speed planes like to make things there own way.
I have started to shape some balsa blocks but just seam to sit there looking at it with out any sort of a plan. I had also thought about making some winglets for it. I don't know if that is a good idea. I have been looking at the wingtips of the planes that were entered in the other post about that german speed event and most look to have a fine taper coming from the root of the wing and have a rounded appearence if viewed from the top down (fore to aft).
thanks for the input guys.
Dave
Old 10-22-2004, 02:22 PM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Other than making a new wing.... you're going to have hard time tapering that wing to infinity...
For your average Q500 aircraft just about any tip is fine (if you're not going for all out Q500 competition that is). I'd say use some foam, and make 'em round: easy, simple and light.
Rudeboy is offline
Old 10-22-2004, 05:01 PM
Ed Smith
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is what I did. I wanted to glass my wing. I had run out of balsa block. So, I stuck a blob of white foam on each tip. I sanded it to shape. I filled it with light spackle and sanded some more. Did this a couple of times until I was satisfied and then glassed the wing. It was no quicker than using balsa but it is lighter.
Ed S
ID:	185468   Click image for larger version
Ed Smith is offline
Old 10-22-2004, 07:13 PM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks good Ed. Like the Vortex tips.
daven is offline
Old 10-22-2004, 07:23 PM
MOJO65-9or10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the tips and photos. I think that is what I will try.
Dave
Old 10-22-2004, 09:33 PM
SSAN
SSAN's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's a couple photos of my wing tips. It's the same as Dave N. stated in his post with 3/16" thick balsa and razor sharp trailing edge glued with balsa triangles. With the 2" taper tips design, it made the plane very table for landing with no tip stall what so ever. Hope this help with some ideas!
ID:	185587   Click image for larger version
SSAN is offline
Old 10-22-2004, 11:07 PM
MOJO65-9or10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Man some of you guys do some REAL nice work.
Thanks again for taking the time and posting the pics. For some of us that are new to speed planes you all are a God send.
Dave
Old 10-23-2004, 07:47 AM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sam,
Thanks for posting a picture of the Razor tips I mentioned above. I checked the inventory, and I didn't have a single Q500 left with that type of tip.
The picture explains it much better than I did.
daven is offline
