HELP --> How To Balance the Magnum
Reply
Old 08-17-2002, 08:28 PM
Isaac F
Isaac F's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default HELP --> How To Balance the Magnum
I dont undertand the instruction on how to balance the Magnum.
The instrucction only says C of G Should be 120-130mm from the Wingroot.
What the hell is WingRoot
Usually all the airplane says the measure from the Leading Edge.
Can some body tell me a VERY EASY way to balance the Magnum.
I want to fly it tomorrow sunday
THX,
Isaac
Isaac F is offline
Old 08-18-2002, 04:18 AM
Isaac F
Isaac F's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Come on People, help me with this. My airplane is ready and I want to fly it. Please help me with the balance.
Isaac
Isaac F is offline
Old 08-19-2002, 01:56 PM
MMallory
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Isaac,
I was confused about this as well. Balance the plane upside down. Measure the 120mm from the leading edge along the side of the fuse.
Mark M.
MMallory is offline
Old 08-22-2002, 02:06 PM
roywiglesworth
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default magnum balance
get it closer to the 130mm i found on mine if its just a fraction
towards being tail heavy it will float in alot smoother.iflew mine the first few flights a little nose heavy and just at the flare it took all up elevator on high rate to keep the nose up in flight i couldn't tell the differece in the little bit of tail weight be landing was a lot better.
roy
roywiglesworth is offline
Old 10-06-2002, 11:42 PM
RampRat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had three flights with my Magnum today after crashing it in a ditch following an empty fueltank in June... Ugly crash by the way... It was nose-heavy, too little elevator-travel available, and the crash-site was 300 meters from the airfield i was flying on. One hell of a landing..
Anyway... Finally decided to get the animal back up in the air, so after installing a heavier battery-pack, increasing elevator-travel, and moving the CG to 130 mm's, the Magnum became a much easier model to handle. The landings are smooth, and the extra weight makes it glide better.
Deadstick was a horrifying event before i added weight and moved the CG back! The speed disapeared in a matter of seconds if i tried to make a turn, but now i glide it at high speed on downwind and the baseleg, and do a steep turn to bleed off excess speed before entering final.
I love this bird!
The Magnum is without a doubt the fastest model on my field, with the exception of a couple of turbine models.... ....and that's more than enough for me!
RampRat is offline
