shrike 10
Reply
Old 11-25-2004, 07:41 AM
RODD
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default shrike 10
i decided to build my shrike 10 with 1/4" carbon fiber rod spars. $6 each at the hobby store. im going to run a os 25fx with a tuned pipe. this is my third shrike and i plan on reinforcing the plane to handle the higher loads. the 1/4" rods fit nicely into the 1/4" square slots. i also used 1/4" round dowel for the leading edge. i glued the ends of the forward spar to the leading edge dowel to give some strength to the last two out board ribs that only have the aft spar. so the leading edge now is also a spar for r4 & r5. i did this to prevent tip twist at higher speeds. i plan on sheeting the entire wing. thanks for all the great ideas on making the shrike stronger.
RODD is offline
Old 11-25-2004, 01:07 PM
Evil Homer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: shrike 10
I built a carbon spar into my Shrike 10 behind the rear main spar and bound it to the main spar, i had swapped out the main spar for a 1/4" spruce and it seams to be holding up ok, i am running an OS32F on the front of mine with an 8x8.
Great fun!
Evil Homer is offline
Old 11-25-2004, 02:15 PM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good looking framework! Here's to hundreds of screaming flights!
combatpigg is offline
Old 11-29-2004, 06:00 PM
TERBObob
My Feedback: (21)
TERBObob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Would somebody be kind enought to tell me where ( online preferrably ) I can buy one of these ARF ? ( or even RTF )
Thanks ....
You can email me directly at :
terboinc@mchsi.com
TERBObob is offline
