1/12 Scale Miss Ashley II pics
Reply
Old 12-03-2004, 01:31 PM
Lownverted
Lownverted's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 1/12 Scale Miss Ashley II pics
Hey Guys
Just thought I'd share some pics of a new bird. For those who aren't familiar with the original aircraft it was a scratch built P-51 fuselage with an -H model vertical mated to a Lear Jet wing and horizontal. Up front was a Rolls Royce Griffon with counter rotating props out of a Shackelton patrol bomber. Sadly it crashed at Reno killing pilot Gary Levitz. It was one of the most attractive of all the unlimiteds in my opinion. Pics of it can be found here: www.warbirdaeropress.com or www.aafo.com
I designed this MA2 in '99 for a loose 1/12 Reno class we raced locally. It is all laser cut with Obechi sheeted foam wing with carbon spars. The canopy and belly pan/scoop are molded fiberglass/carbon. Span is 34 1/2" The prototype was powered by a RJL Conquest .15 piped, weighed 2.5 lb. It did 127 mph flat and level. I always wanted to go faster with it so this one has a Nelson .15 with an enclosed pipe, a few other aero mods and weighs 2.2 lb. Im hoping for 140 mph, we'll see.
Anyone else into 1/12 Reno stuff? I aslo have a Super Corsair built from a Pica kit. In various stages of construction I have a Critical Mass and Stilletto from Airkill kits and a Czech Mate of my own design with a glass fuselage.
Hope to see some pics of your small stuff.
Red
ID:	198920   Click image for larger version
ID:	198921   Click image for larger version
Lownverted is offline
Old 12-03-2004, 08:31 PM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 1/12 Scale Miss Ashley II pics
That is one SMOOOOTH looking plane! Makes me wish there was 48 hours in a day, to make time for building one of those. It will be interesting to hear how the NELSON compares with the CONQUEST.
combatpigg is offline
Old 12-03-2004, 11:38 PM
Lownverted
Lownverted's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the nice words. I hope to fly it in 2-3 weeks. I still need to cut a decal set for it and finish the radio install. Might get slowed up a little though. Look what showed up at the shop today.
Red
Old 12-04-2004, 12:15 AM
xanaphyst
My Feedback: (17)
xanaphyst's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a 1/12 Rare Bear from air-kill with the racing airfoil that I need to get started on after my current list of projects is
somewhat shorter....How do your Airkill planes fly ??? I'm doing mine with a 25FX with the macs header & pipe..
xanaphyst
xanaphyst is offline
Old 12-04-2004, 12:16 PM
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lownverted,
Your Miss is really cute !
Do you have any picture of the enclosed pipe setup ?
Strykaas is offline
Old 12-04-2004, 06:55 PM
Lownverted
Lownverted's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Xan
The Airkill kits fly well especially the Bear. The only thing I have found I needed to change was I took the positive angle of incdence out of the tail. The +2 deg that is in the main wing is fine....It just had too much pich change with speed for my liking. This plane just has no need for decalage. Your .25 with the pipe will make it haul. You can start with a 9x5, and it will accelerate right out of you hand at launch. When you feel the need switch to an 8x6 or 7 and it will boogie.
Strykaas
I will take a few pics of the pipe install for you. Its quite simple really.
Red
Old 12-09-2004, 02:07 AM
Darwin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Red,
Here are my two Airkill planes, the Bearcat Conquest made up (sort of) in the Jet America markings, and the P51-B model. They both have OS32SX power which pulls these small planes close to 150 mph (radar confirmed). I also have the Airkill P51 Strega kit still in the box.
Our club made 1 attempt to race 1/12th scale, but lack of interest killed the event. Oh well. Nevertheless, it was fun to race them the one time. We were limited to .25 size engines for the race, but we could use performance pipes. With the os25fx, the Bearcat was clocked at 125 mph.
Paul
ID:	200951   Click image for larger version
Darwin is offline
Old 12-09-2004, 06:21 AM
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Darwin !
150 mph on such tiny airframes wow !
A few questions :
Are these 1/12th scale ?
Which prop do you use ?
How much nitro ?
And... what are the pipes pictured ?
Thanks for your help.
Strykaas is offline
Old 12-09-2004, 12:39 PM
Darwin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HI Strykass,
Yes, these are 1/12th scale Reno racer kits. Wing span is about 30 inches long and the wing area is only about 240 - 250 sq. inches. They weigh approx 2 lbs (0.9 kg) with engine and radio installed. The wing is balsa-sheeted foam construction.
They were originally designed for 1/12th scale combat, but the designer modified the wings for speed. There is a web site, but it is kind of out-of-date (www.airkill.com) .
I have tried different props, but the best prop for speed with the .25 engines is an APC 8.5 X 5. With the 32SX engines, I use APC 8X6 and 8 X 7. Fuel is 20% nitro.
The pipe on the yellow Bearcat is a Performance Specialties UltraThrust muffler (fits .25- .32 engines), and the red pipe on the P51-B is from Jett Engineering. I forget the model, but it's the same pipe that comes standard with Jett engines. Both work well on the OS engines.
These little planes are the fastest planes I have flown, yet they are surprisingly easy to fly. I have always had a helper hand-launch them for me, however. I haven't tried to launch them myself yet.
Paul
Darwin is offline
Old 12-09-2004, 05:27 PM
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thx Darwin for your detailed answered [sm=thumbup.gif].
You've just totally convinced me at buying one of these kits...
Where can I buy one online ?
Is rudder functional ?
Which servos (high power for such speeds) are u using ?
I would put my Webra .32 on the Bear...
Strykaas is offline
Old 12-09-2004, 08:52 PM
Darwin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Strykass,
The rudder is fixed, and is not really needed since we hand-launch these planes.
I purchased these kits locally since the designer owns a shop only a few miles from my workplace. I know he has a web site (www.airkill.com) but I had to do a Google search to find the email address: airkill@jps.net
Rumor is that there is a short supply of these kits left, but there may be new ones kitted in the future. I suggest sending an email to Jeff Weiss and asking him about the availability. I also saw some airkill kits offered on ebay.
I should probably add at this point that these kits are considered "builders" kits because the instruction "manual" assumes you have built a couple of other kit projects previously. However, I'm sure you would have no trouble building it since you are an experienced builder. One friend who has built a number of them likes to brag that he can put one together in 3 days. However, it takes me much longer!
Hope this helps.
Paul
Darwin is offline
Old 12-09-2004, 09:08 PM
Darwin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Strykass,
I forgot to answer your question about the servos:
I use HiTech HS-225BB for the elevator and aileron and a HS-81 for throttle. I run two 2-25 pushrods to the elevator (left and right side) and solder them together near the servo control arm. The HS 225BB servos are popular with the Quickee-500 crowd and they seem to perform well at high speed.
If you stick to .25 engines or smaller, you can get away with HS-81 for the elev and aileron, but use the bigger servos if you go with the .32 engine.
So, really nothing special about the servo's. No flutter problems seen at high speed.
Paul
Darwin is offline
Old 12-09-2004, 11:46 PM
willflyforfood
willflyforfood's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had mentioned something about this in an earlier post. I love the little 1/12 scale racers. Iv'e got a crazy idea to put my MVVS q-500 40 in a 1/12 mustang. Iv'e got a pica FW-190 that really scoots with an OPS .21, a .40 would be rediculous but a lot of fun. Feedback anyone???
Joey
willflyforfood is offline
Old 12-10-2004, 06:58 AM
Blue_Moon_
Blue_Moon_'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lownverted, how do you meassure the air speed? [&:]
Blue_Moon_ is offline
Old 12-10-2004, 07:04 PM
Lownverted
Lownverted's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Blue
I don't measure airspeed, just ground speed with a radar gun.
Darwin
Have we met? I know Jeff and flew combat (2610 PacNats) for a few years. I was bummed that the racing didn't take off. I guess there was a little friction from the SWRA guys huh?
Later
Red
Old 12-12-2004, 03:29 PM
Darwin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Red,
I'm not sure if we have met or not. I fly at the SAM and Mather clubs in Sacramento. Perhaps at one of the warbird races?
Anyway, I still think the 1/12th scale Airkill kits are one of the best-kept secrets for cheap speed planes out there. The kits are something like $70 and a 32SX is $99 on sale. Not bad for 150 mph worth of fun! I suppose the hand-launch thing might put people off, and then you do need some grassy area to land on.
Paul
Darwin is offline
Old 12-12-2004, 11:00 PM
Lownverted
Lownverted's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Darwin
Yes the small stuff is a blast. Everyone seems to think hand launching is some sort of black art, but when they see it they can't believe how easy it is. As for landing our field is Astro turf and I use a wire skid through the motor mount sticking down about 3" and skids on the other contact points and they survive well.
C-ya
Red
Old 12-13-2004, 02:21 PM
Blue_Moon_
Blue_Moon_'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
were do you got that radar gun from ?
Old 12-13-2004, 08:00 PM
Lownverted
Lownverted's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Blue Moon
I have an older one, but if you search for "Stalker Pro" it seems to be a pretty popular one.
Red
Old 12-14-2004, 11:52 AM
Blue_Moon_
Blue_Moon_'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
is this the same stuff as the police use?
Old 12-14-2004, 11:25 PM
Lownverted
Lownverted's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Blue
Yes same stuff.
Red
Old 07-27-2015, 08:28 AM
windcosmic
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi do you have a set of plans to sell me?
windcosmic is offline
Old 07-27-2015, 05:39 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Where is the picture?
MJD is offline
Old 08-02-2015, 06:37 PM
Lownverted
Lownverted's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
He quoted my original post.
