Whiplash fuel tank(s)
Just when I get my WLash haulin' and settled into the slot ........outta fuel! My DJett 50 goes through 6 oz. of fuel like a snack. I know horsepower cost .... but the thrill is just too short.
I'd be interested in hearing from other WLash drivers with high performance engines. How did you set-up your fuel system. Is anyone using bladders ? I'm using a Sullivan Slant/Flex with receiver foam for dampening and still get a little foam fed to the carb. Props are well balanced (APC/Wood). I dare not use another shot of Armorall. Does anyone know of an airless/bladder tank larger than 6 oz. ?
I'm kinda spoiled but I want my speed in larger doses !!!
I guesss I could back off the throttle a bit ....... Naaaah
Hey Dan... how about some wing tanks ........ Yeahhhhhh wing tanks ____
Hey Dan,
The weather is great ...... 78 deg. with 5-7 mph right down the runway.
Do you ever get back to the west coast ?
Ya know I keep looking at this WLash and a little extra fuel may be possible. What's on either side of the fuel tank? Is there room for maybe a narrow hopper tank like we ran in the ducted fans?
Don't let me distract you ..... 2-4 oz. wing tanks (jettisoned just as you call the ball) would be Ummmmmm!!!
My Feedback: (178)
LA
FUEL TANK
Larry, I was going to try strapping a Dubro 50 ounce on the CG of the whiplash, but my nerves wouldnt take it, so...
If you havent found a bigger tank, call Dan or mysef and we'll see what we can dig up for ya...
My Feedback: (7)
Re: FUEL TANK
Boy I got to get to Louisiana.........
Re: FUEL TANK
If you havent found a bigger tank, call Dan or mysef and we'll see what we can dig up for ya ...
I've been scouring the Web and have'nt found anything suitable so far. Tettra made a bubbleless tank for the pattern guys, but I haven't been able to track it down. Chip Hyde used to carry it, but no more.
Wasn't there a hint of you making your own bubbleless tank ? How about a retrofit of the Backlash tank compartment to my WhipLash?
If ya have any alternatives, I'm interested. I'll have to be satisfied with little doses of fun for now.
But we both know ...... wing tanks are the only cool option !!
My Feedback: (12)
Performance Speciaties....
Has Tettra tanks..and the list on the side of the box goes up to 32 oz (I think)
Give them a shout, or Singapore Hobbies might have a source. At any rate, Tettra does make some larger bubbless tanks.
I know they say do not modify without consulting them but we could not remember who to contact......But anyway on one of our whiplash we removed the throttle servo and relocated a micro beside the tank for the throttle. Then we cut out the tank bay into the throttle bay. This allowed us to put in a longer tank. But on mine going around 200mph I've had enough flying time with the stock tank.
Re: Performance Speciaties....
The willingness to hook a guy up with what he needs in this hobby never ceases to amaze me !!!
Someone always knows someone who knows someone that has what you need.
I'll keep you posted .....
Whiplash fuel tanks
Larry,
I recently did some checking on tank sizes and you can get 2 Sullivan 2oz. oval tanks in the radio bay as saddles. Connect 'em like a DF set up with either the bubbless tank or the stock 6oz and get at least 10 oz of fuel. We're gonna offer the new set up as an option with the Whiplash X starting production very soon.
Re: Whiplash fuel tanks
Originally posted by Noflyzone
Larry,
Larry,
Will the Sullivans fit with the receiver & battery or do I have to relocate them somewhere else ? I'm not sure I can use the Sullivans to feed a bubbleless tank .... can I ? I wanted the bubbleless primarily to get a more consistent fuel flow but if you or someone else know how to feed it ..... I'm all eeeerrrs. :greedy:
Too small & too large
Originally posted by ishu4u
you said you had a jett engine.. did you not know dub jett makes bladder tanks also......better late than never on advice for others.
The 8.5 oz. Tettra comes in at 2.1" W x 4.7" L. After I relocate the throttle, this should fit just right.
