How do you mount fuel tank on Dust???
Reply
Old 02-04-2005, 12:20 PM
cobratraxxas69
My Feedback: (31)
cobratraxxas69's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default How do you mount fuel tank on Dust???
I have a Dust (that I purchased on RCU)...but the fuel tank was super-glued (or epoxied) to the balsa wood floor of the fuel compartment. This has caused a horrible problem with vibration and subsequent severe foaming of the fuel. This leads to air bubbles in the fuel line going to the engine, which causes the engine to run rich then lean then rich then lean. etc.
My question is how do you mount the fuel tank on a Dust? I would imagine it would involve putting foam around the tank to prevent the "foaming".
Your ideas are appreciated.
Mike
cobratraxxas69 is offline
Old 02-04-2005, 01:37 PM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: How do you mount fuel tank on Dust???
The easy way out is to remove the tank and replace it with a bubble-free fuel system.
The DD and Whiplash tank installations were both pretty tight. With higher rpm engines, yes, fuel foam is an issue.
Can you get the existing tank out without destroying too much?
bob27s is offline
Old 02-04-2005, 02:15 PM
cobratraxxas69
My Feedback: (31)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Bob for the response.
I'm not sure how to remove it []...its really glued in there. I would probably have to take a hobby knife to it...
Old 02-04-2005, 06:40 PM
Hotrodkid
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
if its in there good, just knife it and replace it ..... way better then taking an hour to pry it out and still managing to break the plane itself
Hotrodkid is offline
Old 02-05-2005, 08:40 PM
-pkh-
-pkh-'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Another thing you might try is a header tank. Not sure if any of you "speed" guys use them at all. They are common on helis and I've used them on a couple of SPADs where air in the carb fuel line was a problem. Basically, it's just a small 1 or 2 oz tank piped in series with the main tank (between the main tank and the carb). This header tank stays completely full of fuel, with little to no air, so vibration won't cause it to foam. The main tank will vibrate and foam, but it feeds into the header tank, which will keep the carb line pretty well free of air bubbles. Works on my SPADs and my heli... might work on a dust too...
-pkh- is offline
Old 02-06-2005, 12:18 AM
Mike Connor
Mike Connor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Two Dust and well over 100 flights without fuel foaming problems. I used foam aroung the bottom and sides of a six ounce tank with Monokote holding it in. This pic has a sheet of 1/64 ply over the top of the tank.
Mike Connor is offline
Old 02-06-2005, 03:08 AM
cobratraxxas69
My Feedback: (31)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Mike,
Can Monokote alone really hold in a heavy fuel tank (especially during high G manuevers)?
Old 02-06-2005, 11:12 AM
evan-RCU
evan-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, especially since all the "high G" manuvers on a Dust are positive G, The Dust isn't really the best outside loop or 3-D airplane... I used the Sullivan slant 6oz tank that you could heat mould to get it in the spot and not have any problems with the tuned pipe going right above it.
evan-RCU is offline
Old 02-06-2005, 11:42 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike's installation works just fine. Some foam, and gently attached to the airframe. But having it glued to the airframe is likely a serious issue
Id get out the surgical equipment and re-do that section of aircraft as needed.
bob27s is offline
Old 02-06-2005, 12:24 PM
cobratraxxas69
My Feedback: (31)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What do you guys think about using velcro straps attached to the base and wrapped around a foam encased fuel tank??
Mike
Old 02-06-2005, 01:18 PM
Mike Connor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The MonoKote is stronger then a couple of rubber bands that many use to hold their tanks in. As Evan stated, most G forces will be positive and enough negative G's to throw the tank out would probably clear the tail and you would just have a dead stick landing. My main reason for using Monokote to hold the tank in was to reduce drag from an exposed tank. When pushing on my tank you can feel the foam compress. I have read where some just used velcro on the bottom of the tank. The velcro absorbed most of the vibration if the tank did not come in contact with the airframe anywhere. I do not remember reading about any problems doing it this way.
Old 02-06-2005, 01:33 PM
cobratraxxas69
My Feedback: (31)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike,
I've never worked with covering before. Do I just take some Monokote and use a heat gun to make it stick to the surrounding area or do I have to do some additional prep work?
Mike
Old 02-06-2005, 06:23 PM
Mike Connor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The heat gun will help remove wrinkles when you are finished but you need to use an iron to begin with. If you don't have a MonoKote iron you can use a clothes iron but the size makes it more difficult. MonoKote will stick to wood or other MonoKote but the surface needs to be clean. I would take some scrap balsa and your tank and practice some as covering is an art that requires practice and the correct heat. Too much heat will burn holes in your covering and not enough heat makes it not stick well. Covering the tank and makeing it look good is not easy. I would recruit someone with some experience if possible to get you started on the right foot.
The Dust requires rapairs often on the bottom covering because of landings. You can use clear packing tape for small and medium tears at the field but recovering the bottom will need to be done over time. I can recover the entire bottom with one piece of MonoKote in 15 or 20 minutes.
