whiplash
Reply
Old 09-16-2002, 10:18 PM
jlong34016
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default whiplash
Nelson arrived today. QM-40 running 7.4x8 carbon fiber prop apc.
9206 futaba's (132 oz torque @4.8 volts) elevons. bob violet inflight mixture control. expecting 23,000 on the ground and lots more in the air. Engine has throttle. Any suggestions or advice?
jlong34016 is offline
Old 09-17-2002, 12:07 PM
MMallory
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default whiplash
Yep! Wear a diaper and put a pillow between your knees to avoid breakage. You are going to have one heck of a flight.
Seriously, just make sure your prop and spinner is balanced properly and start off with the engine a little rich. Have a helper launch the plane so you can have both hands on the sticks. That's it! If you get nervous...throttle back.
Mark M.
MMallory is offline
Old 09-18-2002, 01:25 AM
BAGOSTIX
My Feedback: (178)
BAGOSTIX's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default wow!!
When you said you were going to put a whiplash together you weren't foolin around were you?
You can expect lots of fun with this baby.
I strongly suggest balancing everything and use lots of thread lock, that kind of Rs will have a tremendous resonance and may loosen lots of screws on the servos and such.
I speak from experience, I had a Jett 50 on one of my whiplashes and the resonance literally backed off an elastic stop nut..
On launch, you may want to give it 1/2-3/4 throttle and build into it once you trim in..
this will come right out of your hands on launch and it wont stop till you throttle back...
good choice in servos, sounds like you have it all together..
Be sure and check all of your controls after each flight.
happy flying, by the way, we will soon be selling pillows on the website for people to use between their knees..
BAGOSTIX is offline
Old 09-18-2002, 01:30 AM
Lee Cox
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default whiplash
I would suggest that a diaper could be conseeded as being a wimp by fellow fliers....all will have flown a much faster ship at some stage, whilst standing on one leg and drinking coffee.
Can i suggest 12 hours before the flight time 2-3 sachets of Immodium should block up most passages that might cause embaressment. Of course a porta potty could be a secondary measure!!
Have fun ....got any pics???
Lee Cox is offline
Old 09-19-2002, 07:08 PM
jlong34016
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default whiplash
Here is previous pic. Will get one with gear installed this weekend.
Old 09-20-2002, 09:34 PM
BAGOSTIX
My Feedback: (178)
BAGOSTIX's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default whipped!!
You should be able to see that one, believe me with a nelson on your whiplash, you'll need all the help you can get... it will probably be a blur... dont forget to put aileron hinge reinforcing tape on the underside of the hingeline... and use that thread lock liberally
BAGOSTIX is offline
Old 10-02-2002, 03:18 PM
ishu4u
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default whiplash
rick just ordered my batman version and see you note about using reinforcing tape on the hinge line. is this just for the older ones and not on the x version i am getting??
ishu4u is offline
