Kaos Duel with Jetts
My Feedback: (63)
Here is the ole' Kaos with new pods holding Jett 40's with 10x6 props. The engines tach at 17,500 rpm and sound awesome. Pods were build to hold
tanks and 1 servo each for throttle. Intial flight was nose heavy, and was corrected by moving battery to extreme rear, sawing off much of nose gear/mount. Plane flys like its on rails and has no bad habits. This is one BAD KAOS!!!
My Feedback: (63)
RE: Kaos Duel with Jetts
No, but we are lookin for one...The dozen of so that viewed first flight guessed between 120-140mph. The engine are mounted as close as you can get comfortably and also offset couple degrees out...so a flame out on one won't affect very much. A nose pod had been build now and CG has been shifted to rear more, on the front side of the stock cg. No other mods have been done to plane..
This would be a hoot to do with a 60-90 size KOAS and a pair of Jett 60's...weeeeha!!!
here are more pics of plane
My Feedback: (63)
ORIGINAL: Crazy4Flight
that BIG flat firewall and cheeks from the original single engine setup have to GO! that is soo much drag there!!!
..........A nose pod had been build now and CG has been shifted to rear more.............
Gone..just did not update new photo's.
Bobzilla
www.theultimategamer.net
Smaller props!
My Feedback: (13)
CA
FD: You gotta give this guy a A for effort in any regard. Look at his first pic. He seems to comply with the "old age" model and certanily is tretcherous in mind if not in deeds. Bering in the very old age class myself, he has my respect. Anyway, whats wrong with the Ford tri-motor, or the 727 for that matter?
