200+ speed demons
200+ speed demons
What planes would fall under this category? meaning planes that could take it stock with any engine. Just wondering cause i think a .40 size shrike would be a fairly good canidate along with a a Diamond Dust.
patternd
RE: 200+ speed demons
In theoretical terms, simple arithmetic tells us that to achieve 200 mph a 10" pitch prop would have to turn at 21,276 rpm. This is theory only ignoring airplane weight, drag and all of the inefficiences associated with turning propellers. As was indicated it would take some power to turn a 10" pitch prop at that rpm.
If you truly wish to fly at speeds well in excess of 200mph, join the glider guys and go "Dynamic Soaring"
Ed S
Ed S
I have had one Shrike 40 and two DD's with Sport Jett engines. My best speed calculations for level flight was just under 180 mph and that was probably a little optimistic. Some claim 200 mph with this type of plane and I would like to see how they did it.
i figured just as much. Considering a prop loses efficency after the tip reach supersonic you could only turn the prop so fast.
patternd
patternd
I don't think a Shrike 40 is going to crack the 200 mark no matter what engine you bolt into it... it is just too fat.
A Dust... Maybe, out of a dive and with some serious (well matched) power.
If you want a 200 mph "stocker", get a Dago Red from Flugapparatebau Wolf ( http://www.f3d.de/ ) with an MB Profi engine or something similar. The plane will do 200 "out of the box", but only if your engine runs right... and that can be tricky... these are not intended for beginners (to say the least). But then again, there aren't too many newbies willing to shell out 2000$ just to show off their skillz...
that's the point. Just thinking right now about the expression on the faces of the jets guys when a prop plane is keeping up with them.
patternd
patternd
Most of the jet guys don't fly anywhere near 200mph. They dont want their $10K planes getting away from them at a quarter mile per second.
WA
Look at a Dynamic Soaring specific model sailplane. They've got the strength to sustain those kind of speeds, and under extremely high sustained G-forces (40-60 g's continuous). Just throw a really high performance setup on it that'll get a pitch speed of about 200mph. Limiting factor will be the $$$$ you've got, because it will be a four digit figure for the airframe and servos alone.
http://www.nesail.com/categories.php...79eee6b1b9506c
http://www.f3x.com/
http://www.rcgroups.com/forums/forumdisplay.php?f=126
http://www.et-air.com/opus/techstuff.htm
http://www.bretamodel.cz/
http://www.hkm-models.com/Dynamod.htm
http://www.icare-rc.com/slope.htm
http://www.f3j.cz/english.htm
http://www.mapleleafdesign.com/ (icon will do it, but you'd better have some $$$$$)
http://www.rnrproducts.com/
http://www.f3j.com/
http://www.shredair.com/wwslope.html (DS tempest)
http://www.tun.ch/
http://www.airplane-model.com/
http://www.volz-servos.com/
whew! That's it!
You'll want to use multiple digital servos on these models, a 5 cell setup, failsafe, etc. Best bet is with Volz servos or the finest you can find.
So you know, the planes that are custom bulit for DS are built to withstand 200+ speeds sustained for however long the battery will last, and have bullet proof wings, well, sort of.
http://www.f3x.com/
http://www.f3j.com/
http://www.tun.ch/
whew! That's it!
i would say shrike if you thin the wings and have the $$$ to use carbon fiber sheeting on it. But i think a dd if you squeeze a jett .90 onto it.
patternd
patternd
NH
I had a Sidewinder quarter 40 model with stock jett Q 40 motor and APC 7.4x8 clocked at 201. I had to dive it a bit though.
You have to figure that the q40s and FAI racers are about the only planes that will do it with the recommended engine.. and that's just because the recommended engine is amazing
ORIGINAL: Rudeboy
Have you ever owned a Shrike 40? While I agree a stock Shrike would have trouble reaching 200 mph I was surprised about how fast it was with a Jett 50. I could not tell the difference in speed between the Shrike and DD just by looking. I think I remember calculating the wing thickness at 12% on the Shrike. However, the WOW factor of the Dust made it my favorite plane.
ORIGINAL: patterndreamer
well if the wingthickness was brought down on the shrike say to about 10% i don't know. Would it make a speed difference?
patternd
patternd
but if i made those changes what speed increases would we be talking about?
patternd
patternd
A conventional design can be made to go faster, ie., like a Q40 airframe than the delta designs. However, the deltas do offer one huge advantage - they can burn off the speed better at high angles of attack without stalling and thus are much much easier to land than a clean Q40 airframe.
NH
ORIGINAL: HighPlains
NH
No kidding about the price.
I'd be interested to know how accurately the q40 airfoils have to be built in order to work reasonably well. You would think that you could get reasonably close by using just one airfoil for the whole wing and making all the dimensions the same. You could even build a slightly slimmer fuselage than the q40 rules allow
good to know. Now all i need to do is save up for the carbon fiber and jett 60 fire and tune pipe.
patternd
patternd
