Go Back  RCU Forums > RC Airplanes > Extreme Speed Prop Planes
Reload this Page >
Prop for weston magnum and weston v2 50
Old 10-07-2002, 07:15 AM
joan
Default Prop for weston magnum and weston v2 50
I have one magnum airplane with the original weston .50 with the tuned pipe, (The engine is a modified webra.50) can any body has experience wit this combo ? Wich prop do you recomend? They recomend a 9x6. Thanks
Old 10-07-2002, 11:10 AM
evan-RCU
evan-RCU's Avatar
We're using 8x9 apc's here...
Old 10-07-2002, 12:10 PM
joan
Default response to my question
Thanks evan
wit a weston .50 and pipe I asume, tell me if you experience any problems when you change the trotle, to me it stoped one. And please how do you take off by hand? there is no place to put the fingers. Thanks
Old 10-07-2002, 12:22 PM
evan-RCU
evan-RCU's Avatar
The throttle repsonese with this prop on the weton motor is great. no hesitation at all when you hit the throttle. We have a helper throw it. It's not as user friendly as a Diamond Dust or Outlaw...But it sure is good looking in the air. And both of the ones here have a cool whistle to them.
Old 10-07-2002, 12:52 PM
joan
Thanks evan
for the first flight do you recomend the CG 120mm from the leading edge and the airplane inverted It's ok?
Thaks again
Old 10-07-2002, 01:40 PM
evan-RCU
evan-RCU's Avatar
we balanced them as recommended and they flew good....
Old 10-07-2002, 05:37 PM
roywiglesworth
best prop we've used so far for the best speed has been apc
9x9 the next would be 8.25x8.75 & 8x9
if you got the first bunch of the combo kits that wasn't a webra
the 2nd generation was the webra thats the one i have a fellow club member got one of those it ran good but i think the modified
webra has considerably more power and throttle response is instance.to get a good launch get your helper to throw it just like a javelen with a finger right on the back of the tail and throw it straight a head never had a bad launch on any one launching this way.and the only plug i've found to work right and last long is a mccoy or a os no.9 i'm running 15% cool power tried al the way up to 50 - 60 % no real advantage .
roy
Old 10-14-2002, 03:58 PM
Cactus.
Cactus.'s Avatar
you can cut an inch off the headder to get it running better on 8x9's, and richen up the bottom end to get the idle to more normal levels with good throttle responce and midrange.
Old 10-15-2002, 05:36 AM
joan
please can you give me more details about this, I thin k it's interesting, Thanks
Old 10-15-2002, 03:10 PM
Cactus.
Cactus.'s Avatar
ermm.. i cant, use a tube cutter to cut an inch off the headder, and a small screwdriver to tweak the mixture...
its just what other club members have done and it's worked. i'll have to let them know about the other prop sizes, tho we use 5%
Old 10-16-2002, 06:14 AM
joan
Thank you for your help
Old 10-16-2002, 03:34 PM
Cactus.
Cactus.'s Avatar
okok, what extra details did you wanna know? i dont own one, but know a fair bit
Old 11-04-2002, 04:25 PM
eugene
where can I get info on acquiring the Weston 50 with the pipe...dealer, phone , Email?? I am only interested in the motor, not the plane ....thanks
Old 11-04-2002, 05:14 PM
Cactus.
Cactus.'s Avatar
www.westonuk.co.uk
Old 11-04-2002, 07:27 PM
roywiglesworth
www.modellbau-usa.com
or call 954-476-5572
741 shotgun rd. sunrise,fl. 33326
Old 11-05-2002, 02:47 PM
eugene
thank you both for the #s and addresses...do either have any experience with this engine -pipe combination?
Old 11-05-2002, 05:20 PM
Cactus.
Cactus.'s Avatar
i dont own one, but 5 friends in my club do, so what you wanna know?
its damn powerful, easy staring, reliable, so far long lasting, easy on plugs, and if you cut 1" off the headder it runs better on 8x8 na d 8x9 APC's ( which it likes best on our Prosynth 2000 5% )
Old 11-05-2002, 06:12 PM
roywiglesworth
motor is hard to beat for the price and performance.i cut 1" off my header but it still doesn't perform on the 8x8 as good as the 8x9
or 9x9 but that could be the altitude where i'm at compared to other people's.the only thing i would suggest when you get it would be to take the back plate and the head off and flush the motor throughly i didn't check mine until after the second tank and the second plug it was full of metal shavings.didn't seem to hurt the motor but i wish i had gotten them out first.
roy
Old 11-05-2002, 06:17 PM
Cactus.
Cactus.'s Avatar
the engine and pipe combo work out to be FARRR cheaper if you get the deal with the Magnum plane.
Old 11-05-2002, 07:52 PM
eugene
Default weston 50
thank you...power, reliability, user friendly.....I have used the Webra Speed 50 in several planes and very satisfied with it...want a little more muscle on a new GP Patriot, and the Webras fit the small compartment best I expected it to be over two bills, thank you for the advice..
