If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 75 of 77 FirstFirst ... 25657374757677 LastLast
Results 1,851 to 1,875 of 1905
  1. #1851
    Join Date
    Feb 2009
    Tuscaloosa, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND FASTER!!!
    I've wanted one of the F-18's for SEVERAL YEARS now !
    I've all but given up on hoping he'd order some !
  2. #1852
    Join Date
    Oct 2002
    East Haven, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've been thinking of scratch building a new fuselage. I have my original that I may be able to pull apart and copy the formers.
  3. #1853
    Join Date
    Nov 2007
    Fort Myers, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Recieved it yesterday! I'm not sure which revision it is. I didn't think to look in the fuse for a number before re-boxing it but it is in thunderbird colors, it came with air retracts and the instruction book is identified as revision 4/06. Assembly will be on hold for a couple of weeks until i re-assemble another project i made some modifications to but i will look in the fuse for a revision number if there is one. It came with the cockpit pan and a canopy but no canopy frame so i will need to find one or fabricate one. Hopefully i can look back through the thread and find some good pics to use as a guide. I don't do scale competition, i build my models to fly so i'm sure i can create one that will work well enough. If anyone happens to have one laying around that would be nice, even from a crash that i could use to make a plug for a new one. It's a great looking plane. I'm looking forward to building it and getting in the air. I have a brand new Jett 90 BSE ready to put in it so i can imagine it will be fun to fly and pretty quick.
    If it helps identify the version number i also noticed in the manual that it states "now features a fully finished canopy/frame assembly. This assembly is held in place with a spring latch." Also it states "The tail cone is now held in place with a single screw."
  4. #1854
    Join Date
    Mar 2007
    Columbus, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Check the CG specification. I had version 3 and it was off by one inch!
    Rick - Columbus, OH
    www.ricktressler.com
  5. #1855
    Join Date
    Nov 2007
    Fort Myers, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: k8svrick
    The manual shows 8-1/2 to 9" behind the leading edge at the side of the fuselage.
  6. #1856
    Join Date
    Mar 2007
    Columbus, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Unless there has been a change to the model, that spec is still wrong. If it is true, I cannot believe after they have been told by numerous people that it's really 7 1/2", that they still publish the old CG. I know Cermark monitors this thread so maybe someone will pipe up and confirm the spec. I discuss this on my website - http://ricktressler.com/id48.html
    Rick
    Rick - Columbus, OH
  7. #1857
    Join Date
    Jun 2006
    Miramar, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If i recall correctly, version 3 also came with air-up spring down retracts, version 2 had air-up air-down.
    Let me know if you want me to take real close pics of my version 3 cockpit.
    Doug.
  8. #1858
    Join Date
    Mar 2007
    Columbus, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Air retracts were optional ($100) at the time I bought mine about 3+ years ago.
    Rick - Columbus, OH
  9. #1859
    Join Date
    Nov 2007
    Fort Myers, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: DougV
    Doug.
    While i failed to closely inspect the retracts i am fairly certain that they were air-up and air-down. The manual also shows that setup. I won't cut the box open again to verify that but i am quite sure they were au-ad. Also, while dry fitting the components i did notice that the front alignment post on the vertical stab (i think it was the front one, the one without the locking screw) was about an inch short of the hole it is supposed to fit into. That is no problem, i will simply have to drill another hole and maybe reinforce the area a little but that may help indicate which version it is. This kit was put together from spare parts and small issues like that are no problem. I was quite happy and grateful that i was even able to get it. Everything else appears to be a perfect match. Any pics of the cockpit assembly would be very much appreciated.
    john
  10. #1860
    Join Date
    Jun 2006
    Miramar, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here you go....hope that helps.
    Doug.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1799371   Click image for larger version.
ID:	1799372   Click image for larger version.
ID:	1799373   Click image for larger version.
ID:	1799374   Click image for larger version.
  11. #1861
    Join Date
    Nov 2007
    Fort Myers, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Perfect! Thanks Doug.
  12. #1862
    Join Date
    Oct 2002
    East Haven, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My Version two retracts are air up spring down.
    Looking for a canopy. I'm thinking of trying to make them.
  13. #1863
    Join Date
    Nov 2007
    Fort Myers, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: LUDS96
    Actually, i have a canopy and the cockpit pan. I do not have the canopy frame. That is what i need. If you make some i would be happy to take one off your hands.
  14. #1864
    Join Date
    Oct 2002
    East Haven, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The frame is painted on the inside. Mine had a cockpit and the Canopy. I'm looking for a Canopy for Version two. I'm thinking of taking the one I have and creating a mold of it.
  15. #1865
    Join Date
    Sep 2003
    Santa Fe Springs, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The original retracts that CERMARK supplied and recommended were Air up & Spring down.
    Peace,
    Steven Chao,
    CERMARK
    Peace,
    Steven Chao, CERMARK
  16. #1866
    miklos's Avatar
    Join Date
    Apr 2004
    Meriden, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've had a couple of version 3's and they were both air up and air down retracts...
  17. #1867
    Join Date
    Nov 2007
    Fort Myers, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I just had to cut the box open again and look, i have air up-air down units. They are sharp looking though! I used au-ad Robarts for years and don't remember ever doing a belly landing due to lg failure. They are nice looking retracts. I'm sure they will work just fine. All i need to do is come up with a canopy frame to get this thing built. I won't be starting on it for at least a couple of weeks so i have time to either find one or fabricate one by then.
  18. #1868
    Join Date
    Mar 2007
    Columbus, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    With regard to landing gear installation, be advised, the mounting plates are inherently weak. Reinforcement with additional plywood is strongly suggested. I published a build log and a detailed procedure I came up with to strengthen that part of the aircraft.
    It is located at www.ricktressler.com.
    Rick
    Rick - Columbus, OH
  19. #1869
    Join Date
    Mar 2007
    Columbus, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Follow up to my last...
    Www.ricktressler.com without the period after the com works. On my previous posting, the message included the period which makes the URL appear invalid.
    Rick
    Rick - Columbus, OH
  20. #1870
    Join Date
    Nov 2007
    Fort Myers, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Rick, i already have your website saved. I'll be reading through it when i get ready to build.
    John
  21. #1871
    Join Date
    Jan 2006
    Texarkana, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My Cermark F-18 and F-16 V3 prop jets both came with air up/air down retracts.
  22. #1872
    Join Date
    Nov 2007
    Fort Myers, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Other project is complete and will be flying in a couple of hours, hopefully. Now i can start on the F-16. Looking forward to getting this thing built. I'll probably start on it today when i return from the field.
  23. #1873
    Join Date
    Nov 2007
    Fort Myers, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    OK, the fun begins. Looking back in the thread Steven Chao noted that version 3 had a latch type canopy. That's mine so i will move on assuming that i have version 3.
  24. #1874
    Join Date
    Nov 2007
    Fort Myers, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    OK, retract mounts beefed up and gear installed. I am working on the stabilators now. The aluminum tubes are quite tight in the bushings. I certainly will not do anything to bore them out so the only option i know of is to lubricate them a bit. Any suggestions here? I have no doubt that my servos will be growling if i don't do something to loosen them up a little. Also, anyone made the stabilators functional and was it worth it? My Futaba 10C can make them operational.
  25. #1875
    vasek's Avatar
    Join Date
    Jan 2002
    Prague, CZECH REPUBLIC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi ft, I would use some lube spray designed for garage doors. Not the oil based ones the ones used on the rubber seals to slide better. Can't remember the name of it... v.
    Remember: Speed is life!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
