Hobbico Spectrum
Reply
Old 10-10-2002, 12:56 AM
wojtek
My Feedback: (72)
wojtek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Hobbico Spectrum
Ok don't laugh .. I think the Spectrum is one os the best flying ARFs out there ... yea its built like crap (gear mounts break, fuselage snaps in 1/2, etc ... ) , but it flies great ... i got mine up to 90mph on a os 46fx with pipe .... i clipped the tail fin durring an inverted pass and the plane is gone .. so im on to another one .. this time im reinforcing the whole plane (and recovering the wings) .... I have a OS 90fx with a tuned pipe going in it ...
my question is ... what is the best prop to use .. i need to get the smalest diameter possible (under 12) to clear the ground on the nose .. will a 12x12 be ok ? or is this still too loght for this engine ? how about 3 blade deals ? what should i use ??
thanx ..
Wojtek
wojtek is offline
Old 10-10-2002, 02:18 AM
jlong34016
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default spectrum
I have put two 90's in 40 sized planes. Both disappointing outcomes. By the time you beef the plane up, put the bigger engine/prop/spinner/pipe/tank, add tail weight...your going to be up about a pound. The fly-ability and performance aren't going to be what you expect. Takes more to get up, hotter landings, snaps like crazy and a hard landing will break something...especially with retracts. I ended up taking the 90's back out. I have found lighter/smaller with higher revving engines to work better for me. This is just my limited experience.But you have to decide what you are looking for...speed...vertical...maneuverability. I didn't see much speed increase with the larger engine either. Airframe/airfoil was more of a limiting factor.
But to answer you question the 12x12 prop will work on the engine and is a reasonable place to start. Field testing will be the only way to tell.
jlong34016 is offline
Old 10-10-2002, 08:04 PM
SSGSPEEDMAN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TRY USING 12x14 APC PROP
SSGSPEEDMAN is offline
Old 10-10-2002, 08:06 PM
wojtek
My Feedback: (72)
wojtek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
12x 14 !! wow, did not know they had one !!
thanx !
Wojtek
wojtek is offline
Old 10-10-2002, 08:10 PM
SSGSPEEDMAN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
YEAH GO TO APCPROP.COM
Old 10-10-2002, 08:21 PM
jlong34016
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 12x14
may need to cut the tips down to get the rpms up into the range you need. Just be sure to rebalance.
Old 10-20-2002, 08:15 PM
SSGSPEEDMAN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HEY LET ME KNOW HOW THAT 11x14 prop performs.
