twin deltas
Reply
Old 10-11-2002, 06:37 PM
marc sommer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default twin deltas
How about this one then?Twin 53s,APCs,4 tanks,spring air retracts.Scarey performance out of my only side by side attempt.By the very nature of the engine position a lot of weight had to be added to the rear end-an obvious solution is to put an engine there instead.Assymetric flight only to be contemplated with a clear head.Please bear with me on these wretched photos-I have been trying to use jpeg but the rcu website says my files are too large,thankfully I am better with aircraft than I am with these contemptable computers.One solution I saw had the props cutting through slots in the wings but,try that with high RPMs and it is asking for a prop break-up due to the change in prop loads with each RPM-I KNOW!!!!!I have another attempt to show you which I shall do as soon as the photos come back from yhe developers.On the building board at the moment I have a machine that is intended to be up with the turbines using two Rossis-I will post its Progress.Regards,Marc Sommer.
File Type: bmp
marc sommer is offline
Old 10-11-2002, 11:43 PM
ZERODOWN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default twin deltas
I want it I want it I want it!!!!!!!!
ZERODOWN is offline
Old 10-14-2002, 03:50 PM
Cactus.
Cactus.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default twin deltas
you given up on that Rapier?
whats this about breaking props? i'm thinking about doing something looking like yours, but a mid mounted MVVS GRRT, 22k
heres your pic as a Jpeg
Cactus. is offline
Old 10-23-2002, 07:17 PM
marc sommer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default twin deltas
Phiily baby,yep,I played around with mid engine deltas last year.They are the obvious solution to virtually every issue using one or more engines,especially cg.Trouble is you lose a massive amount of thrust working the prop in a slot-put the scales on it and you'll see what I mean.Worse than that I had two prop breakages for no apparant reason,but only when I started using higher rpms.Props in slots are pants.I get massive amounts more performance keeping the props external-especially with two engines.Regards Marc Sommer.
Old 10-23-2002, 07:58 PM
Cactus.
Cactus.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default twin deltas
i'm sure i heard you have to have a certian clearance for the prop if you did this. there was an old plane here back in the 80's called a Preditor that was like this, they wernt slow and i'd love to have sommit the same, if only i could find a pic of one.
Cactus. is offline
Old 10-25-2002, 01:17 PM
Dustflyer
My Feedback: (13)
Dustflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Twin Delta
Marc,
Cool airplane! Must have a cool sound in the air.
May you be the first to break the 200 mph barrier!
Dustflyer is offline
