What Delta Plane Mode Is This????
Reply
Old 10-14-2002, 01:58 PM
hilleyja
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default What Delta Plane Mode Is This????
Does anyone know what plane/kit this is?
I picked it up from a swap meet and put a TT GP-42 on it. If flies fairly well the way I have it configured but I would like to know what the proper CG is and the recommended surface deflections.
It has a single vertical stabilizer with no rudder, outside airlons tied to one servo (I would guess bellcranks within wing structure), and a large elevator in the center of the trailing edge. It is setup with landing gears, 2 mains and a steerable nose.
Compared to others I've seen, like the Diamond Dust, it appears to have a fairly thick wing.
I'm not going to break any speed records but even for a TT GP-42 it moves out pretty good. My initial prop was a 10x7, will be moving to a 9x9 to gain some more speed. I'm also looking for a header for the TT GP-42 so I can mount a tune pipe on it.
link: http://www.cma1193.com/MbrHgrPics/hilleyJ2002f.jpg
hilleyja is offline
Old 10-14-2002, 06:16 PM
TRP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The plane in your photo is a SkyFire 40 or the original first run kit ( I forget what name it originally went by.)
I have a complete kit sitting in a box in my building room.
I think the company who built the kit I have is Four Pi? They did a 're-kit' of another manufacturers kit.
If it's built per plans - there is one single servo for the ailerons and nose gear.
Is the motor mount built from two pieces of hard wood?
I was thinking about building the kit I have - except I was going to go with dual vertical stabs - similar to the diamond dust.
How does the stock kit fly? Is yours covered or glassed?
By the way.. here is another thread regarding this plane:
http://www.rcuniverse.com/showthread...hlight=Skyfire
Tedd
TRP is offline
Old 10-14-2002, 10:05 PM
hilleyja
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There is a single servo that controls both the airlons and nose gear. I'm assuming the airlons are directly connected to bell cranks and the servo controls them. The nose gear is a flexible cable that takes a 90-degree turn within the wing before getting to the steering arm.
The motor mount is two pieces of hard wood, though this airplane appears to have seen quite a bit of use and has seen several engines -- motor mount has been redrilled-refilled-redrilled several times, including my engine mounting.
It is covered with a heat-shrink covering, which appears to be in excellant shape.
Can you give me the particulars of the plane, i.e., CG, and control deflections?
hilleyja is offline
Old 10-16-2002, 06:22 PM
TRP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is a phot of the plans:
http://ted.uh.nu/planes/skyfire/DSCF0034.JPG
The CG is clearly marked.
I will get a closer look at the plans tonight and let you know what I find out about the throws.
TRP
TRP is offline
Old 10-23-2002, 09:12 PM
rc yogi 2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
does anybody know of any foam core delta kits
OR foam arf's with symmetrical air foil
rc yogi 2 is offline
Old 10-24-2002, 04:02 PM
ishu4u
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
why not try a whiplash
it is all composit and awsome flyer.. i have the batman original..
joe in ky
i also have a vortex arf that is great but slow.
ishu4u is offline
Old 10-24-2002, 07:14 PM
rc yogi 2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
can't really say I just want foam it will work better for
my secret project .can anyone help
Old 01-11-2003, 08:36 AM
fastlash
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default foam
Scande makes a foam .10 size and a foam core 40 as well if you go to the 1/2a forum some one there has a link
fastlash is offline
