Modified Diamond Dustlike Speed Plane
I am about to start cutting wood on a modified diamond Dustlike speed plane. Here are some of the design elements:
34.5" Span
25" Root Chord (NACA 66-006)
8" Tip Chord (NACA 63-009)
14" sweep back Root LE to Tip LE
3" Sweep forward Root TE to Tip TE
Standard DD .25" Carbon spars and LE's
Fully Sheeted in 3/32" balsa
Here's the kicker...
Cowled side mounted engine for less frontal area (Exhaust port up).
The prototype will have a TT46 Pro. If all goes well a second proto powered by a Jett Fire 50 with a Macs marine pipe semi recessed into the wing for less drag will be built.
The engine mount will be a round pylon back plate mount faired forward to a 1 3/4" spinner.
I have the plans drawn. The only thing left to figure out is the cowling. I have some ideas but I will finalize things when I get to it.
What do you guys think?
34.5" Span
RE: Modified Diamond Dustlike Speed Plane
Here is a my wing plan. The front spar will tie into the LE just like on a Dust. For some reason the right tip got cut when I Jpeg'd the drawing. The plan is correct with symetrical wing halves.
My Feedback: (13)
CA
#1, check your total wing loading with the weight of the Jett 50. Off hand, you may be very heavy. If you can get it off the ground ok, should go very quickly, turining will be questinable I think. Its going to be hot landing I think. You never really know with these things until you try. Start thinking of how you are going to launch this creature. Having a scar at the top of my head, no volunteer here. Saw a nice launch ramp made from pvc pipe sloped upward at about 45%. with about 12" clearance for the prop eather side. Thinking of the same approach for a no gear speed plane with Jett 90L, based on the krangke F20-40 wing, spans about 48", delta shapped. And I am warning you about weght. Almost scrapped the thought process until I saw the PVC launch ramp and wondered why I never thought of that one. Its good to have the group knowledge we all have on this site. Best of luck! Keep us up to date, back to the skunk works.
The wing area is 561 sq/in similart to an unclipped Diamond Dust so the wing loading is very low. A Dust is a 2.2lb plane AUW. With any sport 46 engine a dust will fly out of your hand... no push necessary.
It wont turn fast at all...its a delta wing... but it will go fast in a straight line and land nice and slow.
ORIGINAL: AdrianM
Wont turn fast?? It may drop a little speed in a turn but I have never seen a plane change directions faster then a Dust.
ADRIAN, I scratch built a 90% DD from photos that I found here and at the DD website. It worked out real good! Your drawings are still sketchy, so there are still very inportant details that you don't show. If you dont stray too far from DD build techniques, then you should have a winner [if it isn't overly built], but just strong enough to do the job. If you can build it at 2.2 lbs with a .46, then it should be AWESOME! I think 3 lbs sounds more realistic.
ORIGINAL: combatpigg
I agree... My completely stock Dust came in a 2.5 pounds with an ultra light Webra .32 in the nose and standard size hardware. That's plenty light for a plane this size.
You will be lucky to hit 3 pounds AUW with a .50 size engine and a full pipe... even if you go light on the radio stuff...
