German speed event, when, where?
Hi,
I can not find the thread where you guys was speaking about the german speed event. When? and where in germany is it? Many thanks/Amir
RE: German speed event, when, where?
The event this year will be 1st and 2nd of October in Dachau near München.
Speed's beyond 400 km/h (250 mph) are expected. You can find more informations here : www.mfc-dachau.de
There will be some limitations. Maxium engine size is a 91 (15ccm). For elektro driven the battery size is limited to maxium 1200g (42oz). Maximum overall weight is 5kg (11lb)
This is for safety puposes. No turbine, pulso, rocket or impeller driven speeders will be allowed to take part in the contest. Impeller engines modified to turn a normal prop (not impeller fan) are allowed.
More information about the event last year : http://www.mfc-dachau.de/chro_041010.html or here http://www.mfc-osnabrueck.com/Speedfliegen.htm
Hope that's enough information ?
Hi,
Thank you for all the information. I will check the webpage you represented. Glad to know its not over yet
