Can sb recognize this racer ?
Reply
Old 07-24-2005, 04:16 AM
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Can sb recognize this racer ?
Someone to mention the real aircraft name/manufacturer ? This time I'm a bit lazy. Thx.
Strykaas is offline
Old 07-24-2005, 08:20 AM
nxtdoor
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Can sb recognize this racer ?
Cosmic Wind
Looks like an old Bridi kit. Is the fuse fiberglass? If it is, it more than likely is a Bridi.
Jeff
nxtdoor is offline
Old 07-24-2005, 08:21 AM
HighPlains
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That is a model of a Cosmic Wind designed and built by Lockhead engineers and test pilots in 1946-47. #3, the most famous, is "Little Toni" flown initially by Tony LeVier.
HighPlains is offline
Old 07-24-2005, 08:44 AM
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you !
Apparently Great PLanes sells such an ARF. It seems to have too much dihedral... The one posted above looks just better IMHO.
What are the typical speeds reachable with a good .90 sized engine on such an airframe ?
Strykaas is offline
Old 07-24-2005, 09:38 AM
HighPlains
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Depending on the state of tune of the engine (Jett w/ tuned muffler or sport type engine) you should be in the range of 100 to 125 mph in level flight.
Old 07-24-2005, 10:10 AM
angelrcdesign
My Feedback: (40)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you want to go faster! Make sure that the you build the stab strong enough. or the hole thing.
angelrcdesign is offline
Old 07-25-2005, 09:06 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Of note,
The full scale toni (cosmic wind) has a decent amount of dihedral. It does not affect speed for performance, just provides stability.
Photo of Ballerina and Little Toni
Bob
ID:	301185   Click image for larger version
bob27s is offline
Old 07-25-2005, 11:41 AM
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: bob27s
Yes it does, but only by a very very small amount... Vertical lift provided by a wing with a decent amount of dihedral during level cruise flight is slightly lower than the SAME wing with zero dihedral. Thus, angle of attack will have to be higer on the dihedral wing, therefore increasing form drag . But we are talking small number I guess...
But as you've pointed out, dihedral creates roll stability.
Thanks for these pics ! Do they run Reno races BTW ?
Strykaas is offline
Old 07-25-2005, 03:21 PM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Strykaas
Drag caused by the wing generating lift is called "induced drag" I believe...
Rudeboy is online now
Old 07-25-2005, 03:35 PM
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wing generates form drag (due to its shape) and induced drag (due to lift indeed).
But in this case, we have to compare form drag :
case A : no dihedral, lift generated = aircraft weight
case B : dihedral, lift generated = aircraft weight
As a result, induced drag will be the same in both configurations.
However, given the higher angle of attack in case B, form drag is higher.
Don't you agree, Rudeboy ?
Strykaas is offline
Old 07-25-2005, 03:55 PM
hattend
My Feedback: (20)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Strykaas
Very few Cosmic Winds are racing now, if any. Most are Cassutts or rules specific aircraft.
Here is a list of current F1 planes:
http://www.if1airracing.com/IF1Planes.shtml
Here are past birds (one is in the Smithsonian, can you find which one :
http://www.if1airracing.com/IF1PastPlanes.shtml
Don
hattend is offline
Old 07-26-2005, 06:04 PM
rmh
rmh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you are straining at a gnat--
when raced -those suckers were never in level flight - always turning -or getting ready to turn - but if you like flat wings - have at it ---
I bet the color of the paint would have made more difference.
rmh is offline
Old 07-26-2005, 06:56 PM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I love the green Balerina, is that for sale ?
daven is offline
Old 07-26-2005, 08:44 PM
garys
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave,
I think you'd have to quit racing, if not flying completely, if green paint were to be discontinued..
GS
garys is offline
Old 07-26-2005, 08:58 PM
HighPlains
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gary, it don't matter what color I paint it. It blue shifts when it comes at me and red shifts going away. This also changes the trim on the controls.
Old 07-26-2005, 09:20 PM
garys
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bob, What would happen if you painted the front of your planes blue, and the back red? As far as trim changing, maybe better servos?
garys is offline
Old 07-26-2005, 09:45 PM
HighPlains
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The trims actually change around 500 parts in a billion is you do the math for a quickie.
Old 07-27-2005, 02:10 AM
garys
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bob, so you're saying we can go back to blaming your thumbs for erratic flying?
garys is offline
Old 07-27-2005, 11:08 AM
HighPlains
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That would just about sum it up. I'm fine, plane's fine, radio's fine, but the thumbs suck.[]
Old 07-27-2005, 05:08 PM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Your probably right Gary, then again I haven't gone through a seriously bad drought like yourself. I'd probably switch colors if that were to happen also. I am going back to PPG for my green though, I just don't care for the epoxy greens that are available. I'll stick with klasskote for the clear,white, and black, but I'm back to mettallics.
daven is offline
Old 07-27-2005, 07:30 PM
garys
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bob,
Actually I'd go along with you saying it's those short airplanes rather than the thumbs. [8D]
Dave,
Knock on wood, hopefully I'm through the carnage. Haven't put a scratch in any of my three airplanes with the new scheme, and have four wins, a second, a fourth, and three fast times in seven races with them. Wish I could've made the Nats, but oh well. I know the weather at the beach was nicer than Muncie
GS
garys is offline
Old 07-27-2005, 07:52 PM
HighPlains
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK Gary, I'll add two - four inches to the next one. That and a bit of novocaine injected into the right thumb should slow the pitch response. Also going to drop the V-tail and go to a flat piece of lumber for a change.
Old 07-28-2005, 12:03 AM
garys
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Come on Bob, you're a smart guy, you should know the v-tail's better than a piece of lumber for the tail. Are you going to come to either Phoenix race in the winter? Whatever happend to your Baby Bullet Q40 project you had about 10 years ago?
GS
garys is offline
Old 07-28-2005, 12:35 AM
HighPlains
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, the servos used to fail more often than modern servos do, so I always liked the redundancy of two elevator servos in the V-tail. But the guys in Denver have been rough on the tails of my quickies, I’ve lost two that way in mid-airs when the tail got taken. The second time however, I saved the airplane by rolling inverted and killing the engine. The nose came up due to the pitching moment of the airfoil and it floated in with no damage.
The Baby Bullet Q40 prototype was lost to a bad battery (not enough padding) but I do have another framed up that is several inches longer. But it is too short to meet the rule change we did 5 or 6 years ago. So it sits waiting final assembly and paint. I’ll probably just put a run out Nelson in it and make a slow sport airplane out of it.
I think that I will go to Phoenix this winter, maybe twice. It’s always been one of the fastest places in the country to race, and Jim runs a tight race (if you overlook launching 4 airplanes on three frequencies).
Old 07-29-2005, 04:01 PM
js3
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Red Shift and Blue Shift--I love it! Actually, they do shift in relation to us but it is not perceptable to our eyes. The doppler of the motor is though.
js3 is offline
