Lanier shrike 10 kit
Reply
Old 09-09-2005, 12:01 AM
RC-Captain
RC-Captain's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Lanier shrike 10 kit
will it handle a .28 engine ?
has anybody Incorporated landing gear on one ?
RC-Captain is offline
Old 09-09-2005, 06:28 AM
dkreitz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Lanier shrike 10 kit
I had an os25fx in a Lanier Shrike 10 with no structural problems while flying at speed. But, the larger engine brings higher wing loading with it. The plane was fast and I was learning. Unfortunately, the plane was lost when I turned upwind to land after the engine ran out of fuel. Trying to make it back to the field, I lost too much airspeed and it nosed in from ~10 feet.
dkreitz is offline
Old 09-09-2005, 06:54 PM
RC-Captain
RC-Captain's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks DKreitz, I am going to order the 10. and give it a shot. What the hell it will only be a .28 magnum on the nose. If I don't like it then I will order the 1/2A shrike being that I am leaning toward getting allot of planes in this size range.
Old 09-09-2005, 11:01 PM
FlooredCOBRA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would reinforce the main spar when you build it. If I could have went back to do mine that way I would have. I would use like a carbon fiber arrow rod from walmart or something and expand it to entire wing.
I am running a MVVS Combat Wombat engine on mine and I ended up cracking my main spar twice on mine. I fixed it, well I thought I fixed it but it ended up cracking again. I could see the wings trying to fold when I made my turn back to land. It is fixable but a real pain and totally took the fun out of flying that plane having to fix after flights. If I would have reinforced the main spar I would still be having a good time with it today. Now it pretty much just sits on a shelf collecting dust. A shame too because it was a pretty fast plane and very fun to fly.
ID:	322054   Click image for larger version
FlooredCOBRA is offline
Old 09-10-2005, 12:16 AM
RC-Captain
RC-Captain's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks for the info. How could you let a pretty bird like that just sit on the self ? oh well I can't wait to complete mine .
Old 09-10-2005, 05:52 AM
piper_chuck
My Feedback: (12)
piper_chuck's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Move the firewall back to help deal with the extra weight up front.
piper_chuck is offline
Old 09-10-2005, 09:39 AM
FlooredCOBRA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I know it is agravating to just let it sit. I guess if I put a smaller lighter engine in it it would do okay. Shame though because that engine runs awesome.
I agree with Piper Chuck about the fire wall. The stock location would make the plane to nose heavy with that engine if it was kept there. At the time I was building mine I had already glued my firewall in place then seen on here on RCU about moving it back. I ended up cutting out 2 slots and then sliding my engine mount from the rear through firewall. The engine still stuck out a little further than the length of the fuse so I glued a balsa block to nose. Then I hollowed out the block to make a new nose extention and sanded it to a point to fit my spinner. In the ended so much was cut away that extention didnt hardly weight anything. About the same as a peice of paper.
Also use a flat battery pack and slide it as far back to end of the fuse as you can to get CG.
Old 09-10-2005, 12:16 PM
RC-Captain
RC-Captain's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use 3000Mah battery packs now , and get 4-6 flights in before worrying about changing them. I think the weight of the pack will make up for the weight of the bigger engine.
Old 09-10-2005, 01:04 PM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You only get 4 to 6 flights out of a 3000 mAh battery...? [X(] Something must be wrong...
A plane like the Shrike will do like an entire weekend on a 3000 mAh pack!
Rudeboy is offline
Old 09-10-2005, 01:24 PM
FlooredCOBRA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah something must be wrong if your only getting that many flights with a 3000 mah. I was able to get that on a regular 600 mah back in the day.
I would check all the servos to see if any of them are binding at idle. Maybe the throttle is binding at idle or at WOT.
Old 09-10-2005, 06:05 PM
RC-Captain
RC-Captain's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You only get 4 to 6 flights out of a 3000 mAh battery...? Something must be wrong...
I never said I had to change the pack nor did I say I fly more than 4-6 flights in a flying session. To be honest I am not sure how long a 3000mAh pack will last but I do check after 3 or 4 flights. You never know when the load tester is giving the wrong information.
Old 09-16-2005, 05:11 AM
dkreitz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I found a photo of my old Shrike 10 with the 25FX installed, before its demise. Being small and fast, I opted for a very bright color scheme for improved visability.
dkreitz is offline
