mini speed
Reply
Old 09-15-2005, 05:22 PM
Lomcevak Duck
My Feedback: (14)
Lomcevak Duck's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default mini speed
What do you guys think about the lanier dominator 200? What about with a .15 CV-A on the front end? Does anybody make a tuned pipe for this engine?
Lomcevak Duck is offline
Old 09-15-2005, 08:32 PM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: mini speed
A guy over in the 1/2A forum just built one for .061 power, and it turned out tail heavy. We were just talking about putting a .15 on it to get the CG right. MACs' PRODUCTS can fix you up with an exhaust system.
combatpigg is offline
Old 09-15-2005, 09:52 PM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I built one with a Norvel .061 (I think, it might have been an .074).
Tail heavy like crazy, it needed a lot of nose weight. I didn't have enough throw on takeoff (hand launch) and dorked it. Its been sitting waiting for repairs for about 3 years. I've since robbed all the electronics for a tribute foamie.
I'm not sure of anyone that has flown one. They kinda came and went...
Mines very repairable, just haven't gotten around to it.
I think an OS LA .15 might be ok?? The CV might be a little too much (I don't believe I'm saying this), it is a very small plane.
daven is offline
Old 09-15-2005, 11:11 PM
Lomcevak Duck
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, after long consideration, (about 15 minutes) I decided to give it the old "why not." There is a Dominator somewhere in the mail somewhere between here and Champaign IL wth my name on it. After I get it framed up I'll see what kind of horses I can hitch it to up front. (The .15 CV-A is really tempting...) how close you think I could get to the ever illusive 200 MPH mark? I figure I'll be doing a bit of of glassing and carbon-fibreing.
Old 09-15-2005, 11:55 PM
HaveBlue
HaveBlue's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was thinking something along the same line to break the 200mph barrier, theres a neat little 3 port rossi rated at 35,500 but its a cx12( its actually listed as an aero engine), dont know what prop would hold up to that ..the only other problem I have with the idea is keeping track of a small plane!!! although I dont have a particular plane in mind, probably go for a custom design
HaveBlue is offline
Old 09-16-2005, 07:17 AM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think you will be suprised at how little this thing is. The firewall is barely over an inch square. You will struggle finding a fuel tank that will feed a .15 for very long. Since you will be using a bigger engine, you many not be able to get away with micro servos.
I wish you luck.
Let us know how it goes.
daven is offline
Old 09-16-2005, 10:12 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'd like to see a hot glow engine grafted into something like this!
SOKOL
is an all-molded Hi Tech model for Speed-400 Pylon Racing
Just add your radio and go Fly
Span 720mm (28,3'') Length 550 (21,6) Airfoil MH-43 Wing area 7,1sq dm (110sq in)
Weight 123gr (4,4 0z)
The wing and stab are molded composite.
or this
SUNRACER
Span 980mm (38,5'') Length 620mm (24,4) Airfoil MH-43 7,5%
Wing area 10.334sq dm ( 16.01sq in)
Weight 200gr (7,0 0z)
ID:	324765   Click image for larger version
MJD is offline
Old 09-16-2005, 10:28 AM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One other thing, I intended to put one of my Cox Conquest .15's on the Dominator, and after I saw how small it was decided not too.
Those electrics are pretty cool, I think they will take over the racing scene down the road.
I just don't like hand launched planes with little high pitched props though...
daven is offline
Old 09-16-2005, 10:37 AM
ptulmer
ptulmer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's a picture of a little experiment that I did about three years ago. It's about the size of a dominator and flew nicely with a .15la. With a 7x6 APC it would get up and GO! With a little advice from Combatpigg, there will be a couple of changes and a piped Novarossi .15 is going on the next one.
Steve, there's a pipe for the .15la and the CVX. Either one will be fun, and I doubt that any reinforcing would be necessary. Don't know about the firewall size. I've got a mount at the house I can measure for you later, just let me know.
Sub-micro servos are out of the question. Mini's would be the best in terms of power and weight.
ptulmer is offline
Old 09-16-2005, 11:21 AM
Lomcevak Duck
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for all the advice guys. As soon as the kit gets here I'll start assembly, and shouldn't take me too terribly long to frame it up. I'll do my best to post pics and start a build thread. I may end up putting something other than the CV-A on the nose if it turns out to be way too small. I have a box full of Cox .049s. I love to hear that cantankerously obnoxous sputtering scream of a 1/2 A. and it would probably be small enough to fly in some of the grassy fields around here.
Old 09-16-2005, 11:54 AM
ptulmer
ptulmer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you decide to fly it with a Cox, (or a VA!) replace as much of the wood as possible with lighter, thinner wood. Like Combatpigg says "build a dollhouse with what's in the box" The area of this wing is just about perfect for a speedy .15.
ptulmer is offline
Old 09-16-2005, 09:40 PM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Without question, if you decide to build it for 1/2A power, make the nose about 2 inches longer! Otherwise it looks like a good sled for a hot .15.
