How to get the most from a K&B .48 ?
Reply
Old 10-29-2002, 05:31 PM
BernieG
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default How to get the most from a K&B .48 ?
I am finishing a Morris Hobbies Tomhawk, and have a K&B .48 for it. I am not sure the K&B will be good enough ! What "tricks" would you use to get the most speed possible from that engine ?
What should I expect on which prop ? Any advice on tuned pipe or other exhaust system are welcome.
If you think I should get another engine, which one and why ? Keeping in mind that the nose of the plane is built and I don't want to do big surgery there.....
Was thinking maybe to get a Jett .50, but I am not sure it worth it. Convince me, if you can.... ;-)
Bernard
BernieG is offline
Old 10-29-2002, 11:26 PM
Ross Airforce
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have had a K&B 48 for about 3 years. It is in a "Sig somethin extra".
I did the following to it to get outstanding performance:
1. Remove muffler baffle.
2. Use a perry fuel regulator pump.
3. Use an 11 inch prop( smaller prop will not absorb power)
4. Use high nitro fuel.(also runs great on 10%)
5. Balance your prop.
Be careful to rigidly mount the needle valve assembly.
Also use cushioning material to mount the tank or add a tiny amount of "armorall" to the fuel to supress foaming.
Ross Airforce is offline
Old 10-30-2002, 12:16 AM
BernieG
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, make sense. When you say "outstanding performance", do you have some numbers, so that I could compare mine to "something"?
Bernard
BernieG is offline
Old 10-30-2002, 06:29 AM
Ross Airforce
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry, I have never tached it. It pulls the SE anyway you aim it.
