Magnum R with flaperons : any good ?
I'm wondering if anyone has ever tried this configuration on his Mag, i.e. one servo per aileron and set them up as flaps when landing this thing... As we can read some complaints about its gliding capablities here and there, I may go that route with mine.
Thx !
Thx !
My Feedback: (40)
NJ
RE: Magnum R with flaperons : any good ?
It will drop right out of the sky. and you will need power to come in. and break more props. That if you can cut the eng. just before landing. Good luck...........
Strykaas, I've never had a problem gliding the Magnum, it has a much better glide than the Diamond Dusts, does a real cool nose high glide too, like the Space Shuttle. I haven't looked but will you have enough space?
Thank you for your answers.
Evan, I guess yours is balanced way behind the 140 mm from the LE @ wing root. Have you an idea of your balance point from the LE ? I have to get it right from the very first flight.
And yes the runway is pretty small... and I can't miss it (otherwise, plane is history).
I got tired of having someone hand launch my magnum so I made a launching dolly. It works quite well and is has its own servo for steering . Hard to land on however.
Nick
Nick
You better thnk twice on that flap thing. I have seen two guys here with these things and they are impressive but-----they have no glide ratio and drop like a brick. You need to keep that power up more so than a warbird on landings
My Feedback: (540)
YOU NEED TO WORK TO the Aft CG. A guy in my club was shasing thermals after the fuel ran out. If you are nose heavy they sink and come in fast and you could run out of elevator. just my .02 worth.
Bob Revver # 105
Magnum Jett Sport 50
Whiplash Jett Sport 50
Whiplash Jett FIRE 50
Kobra Jett SS.40
Bob Revver # 105
Kobra Jett SS.40
I think yes there is some margin regarding cg location ... what I would like to have is a good initial setting. I'll perhaps go a bit more aft than instructions (that are all very conservative).
Drnickm, to post a photo, click "post reply". At bottom of box, click "click here to upload". Browse your computer and select photo. Then click "ok".
Here goes
The first photo is the top. the key to the whole thing is a pin sticking up from the dolly which fits into a tube I put in the plane. This keeps it from pulling out too soon.. I also have rails which keep it from moveing side to side. On the undersurface you can see the servo and its own receiver. Does not look pretty but works fine.
