Go Back  RCU Forums > RC Airplanes > Extreme Speed Prop Planes
Reload this Page >
Tuned pipe & air flow question
Old 03-11-2006, 09:33 AM
vasek
vasek's Avatar
Default Tuned pipe & air flow question
Hi all,
I am wondering about fast planes having a tuned pipe change the airflow over one wing. Does it have any effect on the lift of the wing in question?
if yes, what would be the optimal place to minimize the effect? (distance from wing & fuse ?)
any good info on that?
thanks,
Vasek
ID:	424096   Click image for larger version
Old 03-25-2006, 02:57 PM
BMatthews
BMatthews's Avatar
Default RE: Tuned pipe & air flow question
Moved to Extreme Speed Props forum for the best answer.
Old 03-25-2006, 03:44 PM
setxws6
setxws6's Avatar
I think it would have very little effect as far as wing lift. It probably affects cg balance more than anything.
Old 03-25-2006, 08:40 PM
bob27s
My Feedback: (19)
bob27s's Avatar
there may be a small interactive effect at lower speeds.
But the effect will be inboard on the wing, near the wing/fuse interface which is sorta cruddy air anyway. Dont worry about it.
Old 03-26-2006, 01:53 AM
vasek
vasek's Avatar
thanks guys,
SET, you may be right about the lateral balance:
SHOULD one try to counter-balance the pipe weight?
Old 03-26-2006, 07:02 AM
burgh_guy61
I think this was talked about once in the classic pattern forum. I seem to remember that there was no airfoil problems, but the exhaust was causing turbulence over the stab and this is where some of the 70's pattern planes used anhedral in the stab to get out of that dirty air caused buy pipes. As a side note i always lateral balance a plane, pipe or no pipe.
Old 03-26-2006, 03:16 PM
flyingmachine
My Feedback: (9)
always balance the plane laterally
