Speed on a Mach Racer with 46AX 9x8 APC
My Feedback: (17)
And a tower tuned Pipe??
This is my first speed plane so I have no Idea what to expect.
Fastest plane Iv had did maybe 70
IA
RE: Speed on a Mach Racer with 46AX 9x8 APC
I put a o. s 50 with stock muffler on mine also changed vert stabs to a single one with rudder ...first speed plane for me to . fastest thing i had befor was a stinger 10 with a o.s 40 and 10x6 prop and i thought that was fast.. huh cant wait to get my tuned pipe in the mail next week... Oyeh make shur you seal the hinge line
IA
mine had to be going over 150 mph after steep vert dive pulling out just right above the deck and you can do a knife edges with the rudder on it like mine
I doubt that the plane can do 150 mph in a dive even ... the speed of this plane is in the region of only 90 mph max on level flight.
Deal - your prop with the pipe will give you about 15K RPM or so, the pitch speed for that will be about 110 mph ... deduct about 20% easily for plane's inefficiency etc ... so 80 mph is not far at all.
